MSD Fuel Pump and Pump Controller !!!!!!!!!!!!!
Old Sep 13, 2010 | 08:27 AM
buck02's Avatar
Default MSD Fuel Pump and Pump Controller !!!!!!!!!!!!!
MSD Ignition 2225 High Pressure Electric Fuel Pump 75.00 Shipped
MSD Pump Controller 175.00
Adding a turbo or supercharger to your engine is agreat way to improve the power of your car. But you have to remember that when more air is being pushed into theengine, the need for additional fuel raises proportionally.Meeting these new fuel demands could mean larger injectors or ECU programming, both which can be pricey. This Fuel Pump Booster is the economical (and easy) answer for your engine’s new fuel demands.As boost pressure increases in the manifold, the MSD Booster will increase the voltage to the electric fuel pumpto maintain the fuel volume. The amount of voltage is adjustable with a potentiometer from a range of an additional1.5 volts to a maximum output of 22 volts over a range of 5 – 30 psia.
Old Dec 30, 2010 | 09:51 PM
buck02's Avatar
Default Re: MSD Fuel Pump and Pump Controller !!!!!!!!!!!!!
up
ms1motorsports
Feb 3, 2021 09:09 AM
buck02
Dec 30, 2010 09:48 PM
buck02
Jul 24, 2009 08:40 AM
