how hard is the ls/vtec swap.....REALLY?
Old Aug 9, 2002 | 07:45 PM
CRexcellence's Avatar
New User
Default how hard is the ls/vtec swap.....REALLY?
I got off the phone today with some guy from hasports, and he said i am looking at a "nightmare" to wire the ls/vtec motor in my car. Is there any company that makes a good wiring harness that will help my swap go easy? I am running a p72 obd1 ecu and swapping the motor into a 89 crx dx. Any ideas, info, or experience would greatly help me,, just want to plan on how hard this will be
Old Aug 9, 2002 | 10:54 PM
4drlsvtec's Avatar
Default Re: how hard is the ls/vtec swap.....REALLY? (jrx2002)
it's fairly easy your better off using a pr3 or pwo reprogrammed ecu from hasport and use a non obd wiring harness from a 90-91 integra.. then move and add a couple of wires near the ecu....
I've done alot of these swaps make sure that you get a cable tranny and a 90-93 integ. main motor mount that bolts to the block!!!
Doug, 4drlsvtec
Old Aug 11, 2002 | 05:30 AM
New User
Default Re: how hard is the ls/vtec swap.....REALLY? (4drlsvtec)
what main motor mount that bolts to the block are you referring to? I have the hasport kit, are there other components that I will need to make the swap go in? if i go non obd, can i still run the hondata? i was planning on getting the stage 3 nonB. and thanks for the feedback
Old Aug 11, 2002 | 11:58 AM
AzG35's Avatar
Its really not that hard, I converted a DX CRX a couple months back. You will need a new harness(Multi-point FI), extra wire, a soldering iron and about 2 hours. Here are 2 sites that will help you out with the conversion.
http://www.hasport.com/88-91dx_sir.htm
http://b16a.honda-perf.org/prelim.html
SLOENUF
Feb 12, 2011 05:49 PM
14baldo66
Sep 2, 2010 07:05 PM
takumi604
Feb 7, 2005 05:48 AM
hatchBtype_R
May 18, 2002 02:32 PM
