Reliability/weekend track car Is it possible?
Is it possible to have a very reliable DD as well as a weekend track car?
I have a stock b16 eg coupe, with some bolt ons, and i want to go all motor for a bit then turbo it. Would you still be able to build it being reliable as well has having a turbo on it?
Also would it be better to work the b16 or go poor mans type R..
Im looking to get at LEAST 200whp at the least. But i want it to be reliable, and daily driven.
How much would i be putting out with a poor mans type r?
If you build for an all motor setup, ideally you would be raising the compression. Going turbo later would require another rebuild since you would want low compression for reliability. You should plan for either all motor OR boost if you want to save yourself time and money.
As far as reliability is concerned, its all in the build and tune. It depends how much money you want to spend.
well if you build it with OEM specs then yes. Keeping the stock geometry is a good idea for reliability. If honda built it that way, then it was for a good reason. My teacher runs a gsr turbo. Darton sleeved but stock size. Stock crank, forged rods and low compression pistons. STOCK head, crank pulley and cam gears. The motor has 40k on it and runs stock. Oh and he also puts out 320whp.
So if you keep that in mind. Build a solid foundation (i.e. the block [sleeves, pistons, rods]) then whatever your building on top of that isn't going to fail because of a faulty foundation.
so your saying i have to decide whether to go all motor? or turbo because i would be wasting money in the long run if i did an all motor build and then turbo it? because i would be re-doing the build for turbo anyway..
Also if i WERE to do turbo, how much would a good set up cost around,
Any particular reason why turbocharged Hondas aren't reliable?
If your plan is to go turbo, then build the motor for turbo...there's no sense in wasting money and time building an "all-motor" engine when your long term goal is a reliable turbo set-up, which CAN be done.
As for the cost, it just depends on what you want...bolt-on turbo kits can be had for ~$3,000 for a nice one, but once you add in tuning, etc. it adds up, especially if you're paying someone to do it.
My advice is to build the motor for what you want in the long run.....example: I've been running low compression pistons in my B18C1 for two years, and it's naturally aspirated, but I just start ordering turbo parts
turbo can be reliable and works very well as a DD/Race Car. Thats what im doing currently. I built a D series for boost and the way im diong my piping and **** my boost will catch around 4, VTEC around 5. When I get it tuned ill be getting great gas mileage @ low RPM and great power @ high RPM. This is exactly what u want for a daily. All motor doesnt work for a daily and neither does boost if ur turbo spools up @ too low of an RPM. Because you want reliability and gas mileage for a DD. If ur not spooling all the time you dont deal with problems that occur with turbo (since your only using the turbo when your racing), and your not dealing with the gas mileage problems that occur with high compression scenarios (either all motor or while your motor is under boost).
wait, essentially i thought turbo/boost is the same? so boost is different than a turbo?
So to build it reliable and for turbo/boost i would have to go for a lower compression build right? The all motor is going out the window because with the limited budget i have, and the little knowledge i probably wouldnt be able to hit 220 whp all motor on a b16. So if i just boost it, it will be better in the long run? reliability wise? If anyone can link me to some threads where they have info on turbo/boost that would be greatly appreciated. I want to hit at least 250 whp + with the boost. I would also have to get a new suspension set up as well right?
thanks for all the info...
If i were to turbo/boost it i would want to have it reliable for at least 2 years.. I found a really good thread through search going over everything i would need but i still need more information. And through my research, it seems like you wouldnt even have to build the b16 for boost. People seem to be running stock b16's and making 220+ whp easily.
so now the final question is what would be better for reliability/price
an all motor build/poor mans type r or just go boost at like 9 psi and track it on the weekends?
i want to get at least 220 whp (or more for boost) for both, and im doing it in a 93 eg coupe, with full interior/ac/ps
I built a 92 hatch had a built b16 with 198whp. Safety 21 6 point cage and all the other goodies, was my daily driver as well as my track car. I took it to the track as much as I could I also ran it with a/c. The car was totally reliable and I never got pulled over really. It all depends on how you build it really. Here's a pic for reference.
im thinking i wouldnt build it because it would cost almost as much as a cheap turbo set up. And if i did do the turbo, would i have any problems with inspection?
I built that car while I was in High School, it probably cost around 5k to build, as I got some pretty good deals on some of the parts, and I did most of the work myself. It's up to you if you wanna swap cause you'll have to deal with smogging the motor. If you have a carb legal turbo setup you shouldn't have any problems with an inspection, it might be different where you are but here in So Cal its tough.
Car in sig is a very reliable daily driver, and gets about 35mpg (without beating on it). The only thing that is a little bit impractical is that I am always on drag radials and they only last me 5k or so.
I think thats reasonable? I would probably want it tuned at like 6-8 psi on a street tune. I just really want to make sure this is what i want to do. I need to start researching parts, and seeing how much they would cost so i can start saving!
I live in NJ but not in a bad part, but if i do go up to passaic, etc ( some family down there) i will have to be sure to get a new alarm system etc
It sounds like you need to sit down and decide on 3 things.
1. Your goals.
2. Your budget.
3. What it will take to get to your goal within your budget.
1. Your goals.
2. Your budget.
I want to spend at least 2000$ or around 3000$
I want to have it by the summer, or mid summer.
thats a reasonable goal right?
I have been running from 250-300 hp on a couple different tunes on my stock b16 for 3 years, its all in the tune. It can be done for 2000 but you will need to shop smart and pick up some used parts, 3000 would be a more realistic amount.
