BOUNCING RPMs???
Old Feb 19, 2009 | 11:19 AM
B16DelSlo's Avatar
Default BOUNCING RPMs???
i just noticed when im cruising its fine but when i mash on it, my tach needle bounces up like its drunk or sumthing. car doesnt show any difference so i kno its something with the sensor, cluster, or wire to cluster? HELP! ITS ANNOYING! haha. thanks
Old Feb 19, 2009 | 11:42 AM
RagnarX's Avatar
Default Re: BOUNCING RPMs???
Clean your IACV. Should do the trick.
Old Feb 19, 2009 | 01:35 PM
bossm's Avatar
its not you iacv because the motor would idle like **** he said its only the needle that jumps up the motor is running normal and is not revving up its just your electronics
Old Feb 21, 2009 | 04:11 PM
B16DelSlo's Avatar
no1?
Old Feb 21, 2009 | 07:25 PM
95vxtealhatch's Avatar
sounds like a failing vss sensor.
Old Feb 21, 2009 | 07:54 PM
94_DC's Avatar
Same problem with mine. It likes to randomly go to diffrent rpms.
Old Feb 21, 2009 | 08:42 PM
Former User's Avatar
Could be a bad igniter unit in the distributor or a poor connection of the blue tach wire at the igniter. Might even be a bad tach.
Old Feb 22, 2009 | 12:08 AM
94_DC's Avatar
I already know I have a bad distributor, Ill see if it changes anything after replacement.
EJtypeR
Feb 23, 2010 07:45 AM
toolow69
Jul 9, 2009 09:15 PM
92integracer
Oct 15, 2008 12:58 PM
1_slow_crx
17
Sep 16, 2006 08:27 PM
laderj
Aug 17, 2006 02:38 PM
