Bouncing Tach
Old Feb 21, 2010 | 01:45 PM
EJtypeR's Avatar
Default Bouncing Tach
My grandparents have a 98 accord with V-6 auto trans. the tach bounces all over the place. is there a sensor somewhere bad or is the cluser just fugged?
Old Feb 21, 2010 | 04:16 PM
GlassJAw's Avatar
Default Re: Bouncing Tach
Sounds like a loose wire somewhere, most likely the one in the plug on the back of the cluster. Does it stop working sometimes then others fly off the guage past redline??
Old Feb 21, 2010 | 07:26 PM
EJtypeR's Avatar
it reads whatever rpm you are at and then to 0 then back up to what your rpm is back and forth ect... and somtimes its fine...so you think take the cluster out and check the plug on the back?
Old Feb 21, 2010 | 07:27 PM
shietzitzkien's Avatar
vacuum leak somewhere?
Old Feb 21, 2010 | 07:37 PM
redbull-1's Avatar
If there was drivability problems, a bouncing tach could be due to the igniter unit located in the distributor.
However, since it doesn't sound like there are drivability problems, it may be a bad component on the instrument cluster's printed circuit board.
Old Feb 21, 2010 | 11:58 PM
GlassJAw's Avatar
My cluster was doing the same thing, turns out the signal wire from the ECU to the dash had come out of the plug on the back of the cluster.
Old Feb 22, 2010 | 08:27 AM
nus_dogg's Avatar
Mine did that when my Alternator went out. The tech was bouncing all over.
Old Feb 23, 2010 | 07:29 AM
EJtypeR's Avatar
ok ill pull the cluster out and check it.
Old Feb 23, 2010 | 07:45 AM
ilikehonda's Avatar
i doubt it is the cluster. it check all of your grounds and the sensors associated before going through all that hassle
stdefhatch
Jul 2, 2015 04:42 PM
eksedan7198
Nov 1, 2013 04:15 PM
GhostRidaz
Dec 24, 2010 07:52 PM
AFAccord
Jan 3, 2006 05:30 AM
importboi22
Oct 31, 2003 05:20 PM
