Bogging/ power loss issue
Old Feb 19, 2009 | 10:38 AM
G0TB00ST's Avatar
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Default Bogging/ power loss issue
HEY HT,
I WAS DRIVING MY CAR TODAY TO WORK, AND I GOT ABOUT 5 MILES FROM HOME WHEN I FELT THAT THE CAR WAS LOOSING POWER. IT STARTED TO DECELLERATE, AND THE CAR FELT LIKE TI WAS STUDDERING. I TOOK MY FOOT OFF THE GAS, AND WENT BACK ON THE THROTTLE, AND IT WOULD BE OK FOR A FEW SECONDS. AFTER ABOUT 10 SECONDS I WOULD HAVE THE SAME POWER LOSS. THERE ARE NO CHECK ENGINE LIGHTS, NO CODES, NOTHING.
PLUGS WERE CHANGED LAST WEEK WITH NO ISSUES, AND THE CAR HAS A 1/4 TANK OF GAS. wHEN THE CAR IS COLD... NO ISSUES, BUT WHEN IT GETS TO NORMAL OPERATING TEMP... THATS WHEN THE PROBLEM OCCURS!
Old Feb 19, 2009 | 10:51 AM
Joeski99Si's Avatar
Default Re: Bogging/ power loss issue
Have you changed anything else on the car recently ?
G0TB00ST's Avatar
only the plugs...
Old Feb 19, 2009 | 10:55 AM
G0TB00ST's Avatar
damn... im sorry for the caps in the top post
Old Feb 19, 2009 | 11:00 AM
bronx finest's Avatar
did you ensure that the plugs were gapped correctly?
maybe the TPS is bad? does it idle funny?
mikeycivic's Avatar
a ground AGAIN??
Old Feb 19, 2009 | 11:01 AM
G0TB00ST's Avatar
the idle is perfect. the plugs were pre-gapped i believe!
G0TB00ST's Avatar
i doubt its a ground this time.
Old Feb 19, 2009 | 11:03 AM
mikeycivic's Avatar
well here is your problem, STOP STREET RACING EVERYBODY AND YOUR CAR WILL STOP BREAKING LOL
Old Feb 19, 2009 | 11:05 AM
Joeski99Si's Avatar
Tps*
Old Feb 19, 2009 | 11:56 AM
Random_Monkey's Avatar
dam boost, i agree with mikeycivic, stop ****ing racing everyone and anyone that gets near you! lol
bro are you home? ill come trouble shoot it today
Old Feb 19, 2009 | 12:37 PM
G0TB00ST's Avatar
i wont be home tonight...
Old Feb 19, 2009 | 04:36 PM
speedooo's Avatar
unplug 1 sensor at time and see if anything changes
Old Feb 19, 2009 | 04:42 PM
delbert's Avatar
Originally Posted by G0TB00ST
HEY HT,
hey i had this problem before. its your distributor i had this problem last summer driving to my friends house and lucky it was close to my house not outta nowhere pushed the car home in like 100degree weather! took me awhile to figure out what was the problem. but good luck just replace your distributor and it'll be good again. i had same exact problem bogging when normal temp cold start it be running good! good luck
Old Feb 19, 2009 | 04:43 PM
delbert's Avatar
its the distributor guys!
Old Feb 19, 2009 | 10:47 PM
G0TB00ST's Avatar
Now the car hasnt had any issues lately... I dont know... I drove it to lunch and at normal temp.. It was bogging...
On the way home, i decided to drive the car till empty... No problems then. I filled it up and put a fuel injection cleaner...
Still good to go!
Hmmm... Hopefully the problem doesnt come back!
Old Feb 20, 2009 | 02:46 AM
V8 Eater's Avatar
its probably your dizzy as mentioned above, check to see what the crank sensor looks like, look for a crack, even a hair line crack will do it. your best bet replace the whole unit(dizzy)!
Old Feb 20, 2009 | 04:28 AM
GSR936's Avatar
check your injectors maybe 1 went out. pull 1 plug wire at a time when your car is on to see if it wants to trun off.
Old Feb 20, 2009 | 06:44 PM
delbert's Avatar
well i had the same exact problem you had everything the same. came to be my distributor. but if its not doing that anymore than i guess?
Old Feb 21, 2009 | 01:09 AM
SanJose408's Avatar
pregapped? wat kind? i had pregapped ngk iridium.. n they sucked.. pulled em out n found out that i had to gap them myself.. the box even said they were pregapped
Old Feb 21, 2009 | 10:48 AM
G0TB00ST's Avatar
the car isnt having the problem no more... wierd!
Eddog85
Nov 2, 2010 12:11 AM
EG6AAARRR!!!
32
Jun 19, 2007 10:57 AM
schuetts
Dec 11, 2006 08:35 PM
cleggboy
Sep 11, 2005 08:52 AM
Takumi Fujiwara
Apr 22, 2005 06:49 PM
