CTR head VS ITR
Old Feb 21, 2009 | 06:10 AM
g0tgot's Avatar
Default CTR head VS ITR
are there any differences? i found a ctr block for $800, freshly assembled, but i just want the head for ls vtec turbo. is the compression higher than gsr?
Old Feb 21, 2009 | 06:12 AM
91whiteZCrex's Avatar
Default Re: CTR head VS ITR
compression will be lower with a pr3 ( type r ) head than a gsr.... p72 has a smaller combustion chamber
Old Feb 21, 2009 | 06:35 AM
g0tgot's Avatar
so the PR3 would be more ideal for a lower compression rate on a turbo setup, i am trying to get a 9.5 or 9.7-1 comp ratio with a LS bottom end using LS pistons and a thicker cometic headgasket.....
Old Feb 21, 2009 | 07:21 AM
Dogginator's Avatar
Daisy... Daisy...
In general, CTR and ITR heads are the same. The cams are slightly different.
Old Feb 21, 2009 | 09:16 AM
hmoobhero's Avatar
unless its a 00-01 itr head then cams are the same as ctr.
Old Feb 21, 2009 | 10:05 AM
Dogginator's Avatar
Daisy... Daisy...
The 00-01 USDM ITR cams are similar to the CTR. The 97-98 USDM ITR cams were not as aggressive. Only the exhaust cam shares the same p/n for all ITRs and CTRs.
Old Feb 21, 2009 | 11:18 AM
g0tgot's Avatar
thanks !
GSR_hatch936
15
Nov 14, 2008 07:53 PM
eg6-trans
Mar 1, 2008 09:02 AM
_gurusan_
Aug 10, 2005 11:46 AM
hatched92
Apr 12, 2004 07:22 PM
X2BOARD
Aug 9, 2001 11:00 PM
