GSR> Clutch making clicking noises during press & depress
Old Aug 9, 2002 | 06:28 PM
obsidianG35's Avatar
Default GSR> Clutch making clicking noises during press & depress
I took my car to discount tire to get my flat repaired and on the drive back I noticed that my clutch makes a ticking noise all of a sudden. When I press it it makes a sqeaking noise, and the same when I let go of the clutch pedal. When I press pedal very slowly, it makes a "click, click, click, click" noise, almost like a zip tie. Not only can I hear it, I can also feel the click on my foot. I had my stocks replaced to a ClutchMasters only a few thousand miles ago. I don't know if the service guys were neglecting my clutch but I had no problems before I took it in.
I tried messing with the joints on the clutch and it went away at first but came back. I need some suggestions on what this may be???
Thanks in advance.
Old Aug 9, 2002 | 06:38 PM
mattL's Avatar
Default Re: GSR> Clutch making clicking noises during press & depress (r4integra)
i get it once in a while too, but it goes away eventually. I havent been able to find anything to get rid of it, it also annoys the crap out of me
Old Aug 9, 2002 | 07:30 PM
PnX-R's Avatar
Did you try using grease?? That does help in some cases..
Old Aug 9, 2002 | 08:09 PM
Hairy Gorilla's Avatar
Default Re: GSR> Clutch making clicking noises during press & depress (PnX-R)
Are you the same guy that made the post at team-integra.net? We had the same problem over there. Mine does it too. Some ppl said lube up the area in the firewall where the clutch goes through it. That didnt work, so I came to the conclusion that it is the spring above teh clutch that "helps to press in teh clutch for you." It sounds like a spring kinda getting stretched but catching on something then popping. It is like a cracking noise. I am sure other ppl have it like me??
Old Aug 9, 2002 | 08:16 PM
The Poopsmith's Avatar
Default Re: GSR> Clutch making clicking noises during press & depress (TimmyMaryak)
I have had the same problem on and off as well, I havent tried to do anything about it, but its good to hear its not just my car that does it.
Old Aug 10, 2002 | 01:09 AM
3rdGteg's Avatar
Default Re: GSR> Clutch making clicking noises during press & depress (DeeSeeToo)
I had the same problem until I greased the ball joint inside the boot where the slave cylinder connected to the fork (which is connected to the the throwout bearing, etc.)....sorry don't know what it's called so I'm trying to describe it the best I can. Hth.
LandeZak
Sep 9, 2013 10:38 PM
victor.m
Apr 4, 2009 09:19 PM
Tokyo_X-treme_Racer
18
Jan 28, 2004 11:48 AM
p1driftfiend
Dec 30, 2003 07:34 AM
acatak
Mar 21, 2003 01:09 PM
