By passing IAC
Old Feb 18, 2009 | 06:58 PM
NAHHHHH's Avatar
Default By passing IAC
is there any downfall to not running an iac valve
Old Feb 18, 2009 | 09:21 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: By passing IAC
The car will be difficult to idle. Will throw a code 14 if you are using a stock ecu. Not a good idea if it is a stock engine, stock ecu, or daily driver.
Old Feb 20, 2009 | 12:11 AM
rd91sib18c5r's Avatar
I don't know what motor you have but I have done this on several b series motors when
the idle surges on my b18c5 the idle was jumping checked everything and just put a
peice of a soda can in between the throtle body and manifold bloking the iac holes, it's
been like that for years and the only problem is it idles really low when cold but when
warm it drives normal.
Old Feb 20, 2009 | 03:46 PM
NAHHHHH's Avatar
i have b16 with a built head
Old Feb 20, 2009 | 11:50 PM
Why do you want to bypass it? It'll be fine just low idle when cold.
Old Feb 22, 2009 | 10:33 AM
NAHHHHH's Avatar
it was just an idea i saw a friend do it on his and wanted to know the downfalls of doing it and your right it does idle low when its cold out.
joelmatt89
15
Nov 4, 2009 05:27 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
phill
Sep 9, 2004 08:01 AM
dannylDAsport
Mar 28, 2004 11:38 PM
Glocked1
12
Jan 22, 2004 08:13 PM
