OBD I Mugen computer
Old Aug 9, 2002 | 04:21 PM
FyrFytr's Avatar
Default OBD I Mugen computer
I found an ITR with this listed as a mod. It's my understanding that all 96+ cars were OBD II. Is this correct? Will this cause a problem for me? Any thoughts/opinions? I'm ignorant when it comes to technical issues such as this.
Thanks
Old Aug 9, 2002 | 05:04 PM
Bob#455's Avatar
Default Re: OBD I Mugen computer (FyrFytr)
All Mugen ECUs are OBD I. If the owner installed a Mugen ECU, then they had to obtain an OBD II --> OBD I harness. This will disable the secondary O2 sensor (catalytic converter), but should not cause you any problems. Might want to make sure that you are getting the stock ECU as well since I don't think the Mugen N1 ECU will pass emissions.
Old Aug 9, 2002 | 05:06 PM
Chris's Avatar
Default Re: OBD I Mugen computer (Bob#455)
Or you can buy my stock ECU! (2000 ITR)
Old Aug 9, 2002 | 05:07 PM
Bob#455's Avatar
Default Re: OBD I Mugen computer (Chris)
Ambulance chaser!
Old Aug 9, 2002 | 05:09 PM
IGGY's Avatar
The mugen ECU also does not have a knock sensor.
Old Aug 9, 2002 | 05:20 PM
ZygSpeed's Avatar
Default Re: OBD I Mugen computer (IGGY)
I've been running my Mugen ECU for the better part of 30K miles now on the stock valvetrain, no problems, no adapter needed (on a 97ITR).
I'd like to know why you think it doesn't make use of the knock sensor! Ed
[Modified by Zygspeed, 9:21 PM 8/9/2002]
Old Aug 10, 2002 | 11:57 AM
madtypR's Avatar
Default Re: OBD I Mugen computer (Zygspeed)
OBD-I does not use a knock sensor. Also see the http://www.hondata.com website and you'll see that a mugen ECU is really not a worthwhile way to spend $$.
Old Aug 10, 2002 | 12:18 PM
Honda F1's Avatar
Default Re: OBD I Mugen computer (madtypR)
To the best of my knowledge OBD-I DOES use a knock sensor atleast on DOHC VTEC engines. I know that all GS-Rs 92+ have a knock sensor.
Old Aug 10, 2002 | 03:12 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: OBD I Mugen computer (HONDAF1)
It's disabled w/ the Mugen and other clones (in most cases anyway).
Old Aug 10, 2002 | 05:11 PM
FyrFytr's Avatar
Default Re: OBD I Mugen computer (SkyeC)
Grandpa: the car I'm looking @ has other mods (JE pistons & crower cams) & Victor said I should not consider buying it anyway.
[Modified by FyrFytr, 2:44 AM 8/11/2002]
Old Aug 11, 2002 | 08:42 AM
Big Phat R's Avatar
The Mugen ECU uses a unique harness that IS NOT the same as OBD1
BPR - who had to buy ANOTHER jumper harness when he switched from Mugen N1 to Hondata
Old Aug 11, 2002 | 09:42 AM
CPR's Avatar
CPR
Default Re: OBD I Mugen computer (Big Phat R)
BPR - Have you been able to extract more power since you switched to Hondata?
Old Aug 11, 2002 | 10:07 AM
Honda F1's Avatar
Default Re: OBD I Mugen computer (CPR)
Does Hondata disable the knock sensor? What is the reason/value of disabling the knock sensor?
[Modified by HONDAF1, 1:08 PM 8/11/2002]
Old Aug 11, 2002 | 12:13 PM
mafay2's Avatar
New User
OBD 1 P72 ECU does have the knock sensor.
Old Aug 11, 2002 | 03:26 PM
ITR#132's Avatar
Mugen harness adaptor goes from 1999/2000/2001 ecu harness to 1996/1997/1998 ecu plugs. Hondata plugs is 1994/1995 plugs, thats the reason you needed to buy a different harness than the one you had. The Mugen harness is NOT that unique.
vizsual00
Mar 26, 2003 02:35 PM
Mugen Mike
Aug 14, 2002 07:04 PM
slowassR
Aug 1, 2002 05:24 PM
TypeR509
Jan 18, 2002 09:10 AM
