gsr compression help!!!
okay i just check my compression and it was (1-4) 210 130 210 190, as you can see, the 2nd cylinder is way low compare to the other ones. i tried adding oil in the spark plug hole and it jump up to 150, what do you guys think, is it piston rings, my car is still running very powerful though. also, would it be okay if i just grab a piston that still has ring intact with it and just replace it with my piston, would that be okay without no hone or is there something that is require when installing piston.
that's what i'm leaning toward too, but i'm gonna be doing a leak down test this weekend, do you think it'll be okay if i just slap on a used piston with piston rings without doing any work to the block?
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
Calvinator
Nov 14, 2004 09:28 PM
