Did I get everything for my Empty Shell? PLEASE LMK!
So I got my EK shell.
Engine bay is bare as shown.
I got:
-Full JDM B20. From oil pan to intake mani.
----*LS Intake manifold
----*B16 exhaust manifold
-GSR Tranny w/ speed sensor
----*Starter
-OEM B16 clutch, pressure plate, bearing
-B16 Shift Linkage
-B16 Shifter
-B series Axles & Midshaft
-99-00 Civic EX wiring harness (uncut)
-Civic SI motor brackets
-Civic SI motor mounts (looks like I'm missing 1 or 2) But which?
-OBD1 P28 with B20 base map. Disable knock sensor & 02 sensors.
-OBD2b to OBD1 jumper
Stuff I'm missing on top of my head:
-Gasket to swap intake and exhaust manifold
-Oil and oil filter
-New set of spark plugs
AND I NEED ALL THE BOLTS. Bolts for tranny, motor mounts, etc.
So my questions are:
1) Am I missing anything else?
2) Where could I find all those bolts instead of expensive Honda?
Pictures:
I got:
----*Starter
-B16 Shift Linkage
-B16 Shifter
-Oil and oil filter
Pictures:
Thanks.
Sorry for the big pics too, but are detailed :-)
~Bump~ before bed. hopefully I can have some good answer by the morning.
I need this car running ASAP. Hoping by this weekend!
B16 exhaust manifold will not work with the B20, the B20 has a taller deck height than the B16, and thus the B16 exhaust manifold is not tall enough.
What should I do to make it work with the current exhaust system?
Forgot to add that on top.
OBD1 P28 with OBD2b to OBD1 jumper.
B20 base map
Disable knock sensor and 02 sensor.
someone correct me if im wrong...but obd2b to obd1 jumper (might not work) i believe ur car is obd2a. the 99-00 si is obd2b. not sure if there is a difference as to the jumper harness.
But looking good....wish i had money to have my jdm b20v built already!
GOOD LUCK!
GOOD LUCK!
I found a write up.
https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
Seems I got everything, but is there a way to tell what year LS manifold I got?
And double check on the brackets.
Which motor mount I'm missing?
And I don't understand ANYTHING about the air intake. Will it matter, or can I just run normal short ram?
you can run what ever intake system you want.
just make sure it will have enough space for the hood to fully close
EDIT: btw... NICE user pic!!!!
akelly17
93
Sep 8, 2018 06:01 PM
