Apex'i VAFC problem -no vtec
Old Aug 9, 2002 | 02:23 PM
The Poopsmith's Avatar
Default Apex'i VAFC problem -no vtec
I just finished installing a VAFC i bought. Everything is operational, I double checked all the wiring. Everything seems ok, but I just took it out for a test drive and Vtec is not activating. I messed with the VAFC and got it show VTi and VTo, VTo is activating, but VTi is not. What could the problem be? The sensors are set to 6 6, is that what they are supposed to be set too? Help me...
Old Aug 9, 2002 | 03:36 PM
B00ST2nR's Avatar
Default Re: Apex'i VAFC problem -no vtec (DeeSeeToo)
did you reset your ECU after you installed the VAFC? Did you set your car type to 4 cyl.? Try that out. I had the same problem, but later found out I had it on 6cyl instead of 4cyl. It fixed the problem.
Old Aug 9, 2002 | 04:30 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
also double check your wiring again... specifically check the VTEC wire...
[Modified by dLo GSR, 5:30 PM 8/9/2002]
Old Aug 9, 2002 | 08:04 PM
Default Re: Apex'i VAFC problem -no vtec (dLo GSR)
Done and done... still no vtec, what sensor types are 96-98 integra GSR's supposed to be set too? mine are at 6 6 right now
Old Aug 10, 2002 | 05:22 AM
TRuST's Avatar
It's 6 6 for the integra. I would look at the VTi and Vto wires, they might be mixed up. I believe the VTi is on the ECU side of the controller and the Vto is on the engine side of the controller. If you are still having problems reconnect the VTEC wire and see if you vtec comes on now.
Old Aug 15, 2002 | 02:30 PM
speedymon's Avatar
Default Re: Apex'i VAFC problem -no vtec (TRuST)
Hey just thought about it. Did you connect the VTM wire? It's not in the instructions you have to go to the site and look up the pin position.
Old Aug 15, 2002 | 03:32 PM
allmotorls95's Avatar
ur probably driving a ls..
Old Aug 15, 2002 | 04:28 PM
bullz's Avatar
Default Re: Apex'i VAFC problem -no vtec (allmotorls95)
Old Aug 15, 2002 | 05:02 PM
HAHa....Your wasting your posts newbie...
Old Aug 15, 2002 | 05:15 PM
notice how his name is DC2 and not DC4?
Old Aug 15, 2002 | 05:18 PM
jdmfront's Avatar
I had the same problem. Its the VTM wire.
USDM 4G VTEC
15
Oct 10, 2003 08:19 PM
COLORPROS
Feb 4, 2003 09:29 AM
The Poopsmith
Aug 9, 2002 10:18 PM
VTC_CiViC
Sep 13, 2001 08:38 PM
