harness bar?
Old Feb 17, 2009 | 05:33 PM
turbo-crx's Avatar
Default harness bar?
i have a crx and want to install a harness bar. My ? is what kind of metal do i use to weld to the car and where do i held it to inside the car? im not sure how high its suppose to go when welding it. thanks.
Old Feb 17, 2009 | 08:38 PM
kmt63's Avatar
Default Re: harness bar?
they are bolted in or part of your roll cage.the height is specified from your 4 or 5 point seat belt directions.or you can find it at simpson.com or impact.com one of the seat belt mfgs sites.the tube should be at least 1 1/2 .095 wall dom.
Old Feb 17, 2009 | 10:17 PM
Baxt3r's Avatar
Are you wanting a roll hoop or just a harness bar? You could copy the sparco harness bar:
http://images.turbomagazine.com/feat...Rear_Seats.jpg
the bar should be approximately 5 degrees below your shoulders.
Old Feb 18, 2009 | 05:27 AM
Blackcatn2o's Avatar
Are there any out there for a 3 point harness's?
Old Feb 18, 2009 | 05:59 AM
turbo-crx's Avatar
i have RCI 5 point harnesses. i just need something i can bolt my harnesses to other than my seat.
Old Feb 22, 2009 | 09:04 PM
LS_teg's Avatar
the only thing that he didn't tell you was the material, you should use chromoly.
Old Feb 28, 2009 | 05:07 PM
bigTom's Avatar
nhra calls for a minumum 1.250x.065 4130 tube for the harness bar when in a rollbar/cage. it must sit no lower than 3" from your shoulder... it cannot be located abover your shoulder
meheartmycivic
Sep 2, 2009 09:46 PM
streetsold6teeny8
30
Aug 29, 2009 02:49 PM
boosted91crx
16
Apr 28, 2009 08:57 PM
xci_ed6
Dec 27, 2008 01:44 PM
Power Rev Racing
10
Dec 19, 2005 06:55 PM
