cant get my car started after swapping blocks.
Old Feb 17, 2009 | 01:21 PM
vlc92189's Avatar
Default cant get my car started after swapping blocks.
Hey guys i have a JDM B16 odb1 into a odb2 car. car ran great. decided to sea foam the motor, revved the **** out of it until i had on oil in it and burnt a rod up. well it messed other things up as well.. it still ran until i recieved a new block and put the block on, replaced head gasket and such. I did take the motor out of the car to do all of this, now i cant get the car to start. any suggestions? the car is grounded correctly, ignition coil is good. seems to be getting fuel? im stumped.
Old Feb 17, 2009 | 05:58 PM
vlc92189's Avatar
Default Re: cant get my car started after swapping blocks.
anyone?
Old Feb 17, 2009 | 07:00 PM
bossm's Avatar
is the car trying to crank or does it just sit there dead
Old Feb 17, 2009 | 08:25 PM
vlc92189's Avatar
it cranks as it wants to start but it doesnt. as if the ignition coil is shot but it's fine. brand new and tested.
Old Feb 18, 2009 | 06:17 AM
vlc92189's Avatar
anyone?
Old Feb 18, 2009 | 08:21 AM
. o 69 o .'s Avatar
you have fuel? you have spark? it could also be something as simple as your distributor is out 180 degrees. That would cause it to crank, but it would be firing the wrong cylinders, also, make sure you set up the timing belt properly, a few teeth out and it wont start... oh yea, and don't Sea Foam your motor
Old Feb 18, 2009 | 09:50 AM
bossm's Avatar
k check the plugs,wires
are all sensors in the right way i doubt its your dizzy but just double check if its right in the middle where its supposed to be like he said could be a lil off
Old Feb 18, 2009 | 10:06 AM
D16SohcVtec's Avatar
Check for fuel, check for spark, check timing.
Old Feb 18, 2009 | 12:28 PM
vlc92189's Avatar
im going to check timing soon. i hope i have good compression.
Old Feb 18, 2009 | 01:50 PM
ehJay's Avatar
Yepp. You're going to have to check your compression.
Check it and update us.
texuslove
Jun 11, 2015 05:10 PM
K i l l a B e e.
Jan 27, 2009 06:07 AM
AllSpedup04
Aug 16, 2005 02:27 PM
infinate bound
Mar 19, 2004 02:25 PM
