Springs Making noise
I installed my H&R springs the other day. The fronts are making a creaking noise when I go over bumps. The rears are fine. It could be my struts making the noise I guess. Even when I push down on the front end they make the creaking noise.
Any ideas?
Thanks
-Kyle
Any ideas?
Thanks
-Kyle
my pro kit did the same thing. the noise was made by a loose bolt that hold's the sway bar down. If that's your problem take your wheel off, and grab the sway bar. it shouldn't move much, but if it is loose you'll know that's the problem right away.
My old springs used to sing when I would turn the steering wheel while stationary. The like rubbing a crystal glass with water, except different sound. My eibachs have done it a couple of times.
