Tuning question for experienced tuners only
Old Feb 17, 2009 | 10:31 AM
b16jared's Avatar
Default Tuning question for experienced tuners only
I have a 99 si that i want to tune myself i have apexi neo and aem wideband. The biggest part of the question is the uego reads rich in vtec like around 11.0 to 13.0 can i lean it down reliably or is it supposed to run rich during high revs? I also have the basics i/h/e full msd.
Old Feb 17, 2009 | 10:40 AM
Marauder's Avatar
Default Re: Tuning question for experienced tuners only
I personally wouldn't lean it out more than 13:1, but the 11:1 is a tad rich. I'd target around 12.5:1 to 13:1
Old Feb 17, 2009 | 11:26 AM
b16jared's Avatar
Thanks for the suggestion. It normally runs around between 14 and 15.5 before vtec without correction. Anymore suggestions would be appretiated.
Old Feb 17, 2009 | 01:42 PM
andoxviii's Avatar
You should post this in the Engine Management and Tuning forum.
Old Feb 17, 2009 | 01:47 PM
98vtec's Avatar
moderator emeritus
an engine typically will make its best power at a ratio of around 13:1. Aim for that ratio across the board and know that you will get to a point (even before reaching peak rpm) to where the fuel graph will flatten out and you will actually have to take away fuel in order to maintain a 13:1 AFR.
Old Feb 18, 2009 | 09:19 AM
b16jared's Avatar
thanks 98 i have ran lots of bolt-ons but i am new to fuel management. I have been trying to find out what ratio makes the best power.
Rome3aaro
10
Sep 29, 2011 11:39 PM
O16581724 5 2 5
Feb 16, 2006 10:42 AM
SpoonFedHatch
Feb 24, 2004 06:20 PM
Eresuncabron
Oct 28, 2003 01:24 PM
ITR41
Oct 28, 2001 11:02 PM
