No spark after some engine maintaince, please help
Old Feb 17, 2009 | 09:57 AM
9818tegr's Avatar
Default No spark after some engine maintaince, please help
Hey guys, I have a 98 gsr, as the title states I have no spark being thrown to any cylinders after we did some maintaince. We pulled the engine to do the work. It was running fine before we did the maintaince. Now after the work we cant get it to throw a spark. A couple of weeks ago we kinda had the same problem, was not getting a spark to any cylinder, found a bad coil to be the reason. Replaced the coil pac and it ran fine for a couple weeks untill we tried to do some maintaince, which included plugs, wires, timing belt, h2o pump, valvecover, etc.. Hooked everything back up after maintaince and got no spark. We even tried a new coil pac incase the new one was bad. Still nothing.. Just verified that the timing belt is in the right position on the gears.. PLEASE HELP!!! I NEED MY CAR RUNNING... ANY SUGGESTIONS OR HELP, PLEASE...
Old Feb 17, 2009 | 11:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: No spark after some engine maintaince, please help
Start by making sure there is power to the distributor assembly, [black/yellow] when ign. switch is on, if so, check the ICM in the distributor, maybe it was the problem all along.94
PS, insure all connections to the coil/ICM are solid/tight connections.94
Old Feb 17, 2009 | 01:12 PM
9818tegr's Avatar
it might be the ICM. we have power to the distributer..
Old Feb 17, 2009 | 03:44 PM
9818tegr's Avatar
All connections seem to be good and tight. Anybody else have an idea?
Old Feb 17, 2009 | 04:10 PM
slomofo's Avatar
GDD Member
So you actually pulled the engine out to change the waterpump and do a tune-up? hahahahahaha... oh right, sorry man, I couldn't help myself.
Anyway, pull the distributor cap off, turn the key on and check to see if you're getting power to the coil, if so, then the problem is somewhere in the distributor, but if not, then follow the source of the power with the test light and see where the problem is.
Old Feb 18, 2009 | 11:04 AM
9818tegr's Avatar
We also had other shi- to do, timing belt, throwout bearing... We just figured it would be easer to pull the engine.. U disaggree? At this point we think its the ICM/ distributor..
Old Feb 18, 2009 | 07:41 PM
crooklyn_outlaw's Avatar
try new dizzy if not then check ecu fuse next to battery.
Old Apr 2, 2009 | 06:51 AM
9818tegr's Avatar
replaced with a new dizzy, and she fired right up..
e-roc88
Nov 1, 2010 03:39 PM
hondalord
May 27, 2010 08:42 PM
jay5555ca
Sep 17, 2009 01:39 PM
lina sok
Mar 20, 2009 09:30 PM
rpv173
Jul 24, 2005 09:15 AM
