warped flange
Old Feb 17, 2009 | 04:57 AM
bigD's Avatar
Default warped flange
picked up a used ramhorn manifold and the turbo flange is a little warped, I hit it with my bench top belt sander to show the high and low spots. Is it ok to just go at it with the sander till its flat or should I have it machined? Aslo it has no markings so If anyone has a idea who it may have been made by let me know, or what you think about the qaulity. thanks
Old Feb 17, 2009 | 05:12 AM
Blackcatn2o's Avatar
Default Re: warped flange
I've never delt with a turbo befor but if a gasket goes between the flange an the turbo i would say just use the belt sander
Old Feb 17, 2009 | 05:28 AM
Snafubmx234's Avatar
Belt sander for sure. I can't see pictures at work, but I assume it's not too bad from how you worded your post.
Old Feb 17, 2009 | 05:29 AM
silly sohc's Avatar
Its mine, I couldn't tell you how long ago. I've been doing split Honda flanges for about 5-6 years. If your belt is low speed then give it a couple seconds on there at a time, so long as you are good at applying even pressure. I'll usually run a multi-ply gasket on the stainless flange. If you want it guaranteed perfect - then machine it.
Old Feb 17, 2009 | 09:39 AM
bigD's Avatar
thanks for the help, that means its of good quality and has a lifetime warranty right think ill give it a go with the belt sander first if im not happy ill machine it
HamiltonRex
Welding / Fabrication
Apr 21, 2018 12:05 PM
nonamedude
Jun 15, 2009 07:20 AM
bigD
Feb 14, 2009 04:27 PM
ophdehEEEzy
Sep 22, 2006 06:41 PM
ityab0y
Feb 15, 2005 09:48 AM
