94 civic ecu
Old Feb 17, 2009 | 04:41 AM
cookiemonster's Avatar
Post 94 civic ecu
what is a good ECU to run in an obd1 civic with an obd2 B18 LS?
Old Feb 17, 2009 | 05:03 AM
Lasky's Avatar
Default Re: 94 civic ecu
you should get a jumper harness so you can run an OBD 1 ECU.
http://www.phearable.net/shoppingcar...sses-c-28.html
thats the link to the jumper harnesses, you just have to find out if you need OBD2A to OBD 1 harness orr OBD2B to OBD 1 harness.
that website also sells chipped p28's, which would be fine for your set-up.
Old Feb 17, 2009 | 08:28 AM
94EG8's Avatar
Seagull Management
OBD1 P74, P75 or Chipped P06
Old Feb 17, 2009 | 09:05 AM
CivicSpoon's Avatar
His car is OBD1, so he won't need any conversion harness to run an OBD1 ECU.
Old Feb 17, 2009 | 09:29 AM
it has the stock 94 OBD1 ECU. im having to put anothre B18 in it and i wanted to upgrade the ECU with something better.
2manytoyz
Apr 11, 2012 04:49 PM
NsX_CrX
Nov 19, 2005 12:49 PM
mister_r0b
Apr 2, 2004 07:49 PM
Hites
Nov 25, 2003 04:41 AM
slowhatch4now
Sep 19, 2003 06:28 AM
