d15 turbo
Old Feb 16, 2009 | 11:57 PM
mario626's Avatar
Default d15 turbo
i have a d15b7 engine and i wanna go turbo what will i need to go turbo
Old Feb 17, 2009 | 12:03 AM
D16SiHatch's Avatar
Default Re: d15 turbo
although this is for a b18, you'll get the jist of what you need
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
Old Feb 17, 2009 | 12:04 AM
andoxviii's Avatar
Thats quite the first post. Welcome to h-t.
So, you want to go turbo? I don't blame you, that's a terrible engine to daily drive as it is. No power, no torque, and lonnnng gears.
These links will help you...
http://www.beesandgoats.com/boostfaq/g2icturbo.html
http://www.hondacivicforum.com/forum...ad.php?t=42034
https://honda-tech.com/forums/showthread.php?t=1263795
I got all three from the FAQs thread that is stickied at the top of the forum. You should do some exploring in there, too.
Old Feb 17, 2009 | 12:16 AM
D16SiHatch's Avatar
true. perhaps i should of gave him a link instead on how to swap that engine out for something with more potential lol
Old Feb 17, 2009 | 12:32 AM
andoxviii's Avatar
^^ haha
Maybe you're right...
Old Feb 17, 2009 | 04:53 AM
EJdrew's Avatar
Yeah, a D15B7 does not have much potential, I know because I have one.
I would go with AT LEAST a non v-tec B18, like a B18B1.
Old Feb 17, 2009 | 07:39 AM
Unseen Racer's Avatar
go to the FORCED INDUCTION forum there. they will help you out tremendously.
and i would just go for a b18c5 swap. or even a b16 swap instead of a turbo d15. then later on, turbo the b18/b16
Old Feb 17, 2009 | 09:17 AM
PeakBoostEg's Avatar
Really are they really still that bad even after being turbo'd?? i have a gsr but i wanted to suggest to my friend he should turbo his d16 and maybe do a mini me setup what kind of power could he expect???
Old Feb 17, 2009 | 09:54 AM
well the d15 has slightly more power than the d16s at higher rpms. but its not much. they also have a more aggressive cam than the d16 but its VERY VERY hard to notice as it doesnt make much difference.
and if your friend has a y8 then he can just put a turbo on it cuz of its low compression. but he will only have 225whp MAX.
anymore and his rods wont take all that extra hp. then they will snap
Old Feb 17, 2009 | 10:06 AM
andoxviii's Avatar
They aren't that bad to turbo, no. Pretty much any engine is fun to drive once it's turbocharged. You never mentioned which D16 your friend has...but considering you also spoke of a mini-me swap, I'm going to assume its a D16Y7...? Well a Y7 that has a VTEC head will perform like a Y8. A 1.6L VTEC d-series will perform better than a 1.5L non-VTEC d-series, assuming everything else is equal/comparable.
Which D16 and D15 are you comparing? The only D15 with aggressive camshafts is the JDM D15B, not the USDM D15B7 that the OP is talking about.
Old Feb 17, 2009 | 01:14 PM
mario626's Avatar
do i really neeed to chip my ecu even if im only gonna boost like 8psi
Old Feb 17, 2009 | 01:17 PM
andoxviii's Avatar
YES. When performing any significant engine work (like adding turbo, or building the internals of an engine) it is VERY important to tune the ECU properly.
citystreetsbimmer
Northeast (Sales)
May 21, 2008 08:01 PM
trbcivic
Sep 22, 2003 11:58 PM
