GSR ECU swap question
Old Aug 9, 2002 | 12:54 PM
mrlegoman's Avatar
Default GSR ECU swap question
swapping a 94 gsr engine into a 96 civic ex.
Is the ecu plug and chug, or is there going to be some rewiring involved?
I'm swap illiterate and I'm learning as I go.
Note:
Yes, I've done a search.
Old Aug 9, 2002 | 08:33 PM
salbaje's Avatar
Default Re: GSR ECU swap question (mrlegoman)
use your ex harness and obd2 gsr ecu or ecu jumper harness and obd1 ecu
Old Aug 9, 2002 | 08:44 PM
poison's Avatar
yes, as far as plugging it into the P72 ECU, it's plug in, you can use the obd1 gsr harness, but you will have to wire up knock sensor thru the firewall to the ecu, i believe, other than that, you're fine from there.
Michael1989
10
Aug 24, 2008 10:38 AM
d!ckface
Jan 30, 2007 05:09 PM
mr 636
26
Mar 22, 2006 12:39 PM
ingrate
Jul 17, 2001 10:38 AM
