will this short shifter fit?
Old Feb 16, 2009 | 09:54 PM
mynameizstitch's Avatar
Default will this short shifter fit?
ok i will be ordering a fidanza short shifter. my car is a 93 civic hatchback with a b16a3 swap. i was wondering if this one would be ok since i have a b16a3 swap and was concern since the shifter and shift linkage may be a lil different. it states that it will fit 88-2000 civics.
here is the link to the short shifter i want to order.
http://www.autoaccessoriesgarage.com...ID=1003&vlink=
Old Feb 16, 2009 | 10:13 PM
98civdx's Avatar
Master Detailer
Default Re: will this short shifter fit?
it will NOT fit.
your going to need a shifter for b series, that is a d
Old Feb 16, 2009 | 10:43 PM
so any b series shifter should fit? like the ones made for integras or 99-00 civic si?
Old Feb 16, 2009 | 11:21 PM
ixoiiiiviviiivi's Avatar
Any d series shifter will fit and so will the b16 shifters. integra (b18) shifters will not fit unless you modify the shift linkage. (they tend to be about half an inch wider and will not fit in the fork of the shift linkage)
Old Feb 17, 2009 | 05:36 AM
ok so im confused now one person said any d series shifter will fit or a b16 shifter. i just want to confirm is that true?
Old Feb 17, 2009 | 05:44 AM
delsolsi193's Avatar
you need a b-series shifter for a b-series tranny.
Old Feb 17, 2009 | 07:09 AM
hmoobhero's Avatar
yup, but never tried using d series shifter on b series shift linkage. mite work. try it and let us know.
Old Feb 17, 2009 | 10:49 AM
98civdx's Avatar
Master Detailer
just get like a 99-00 si shifter and put it in,
i have never tired an itegra shifter but i have been told they dont fit.
Old Feb 18, 2009 | 01:59 PM
Depending on the shift linkage you have put in. If you have a B16 Shift linkage ANY D SERIES or B16 shifter will fit. Integra (b17/18) shifters WILL NOT FIT. Doesnt matter even if theyre B series. They will only fit if you have a B18 Shift linkage. The only way to get the b18 integra shifters to fit is to grind them down about 1/2 and inch. the b16 shifters will fit in the b18 linkages with spacers to fill in the gap. the fork size is narrower on b16 shift linkages. look up the differences if you dont take my word for it.
Old Feb 18, 2009 | 02:11 PM
bigBOI_92DA9's Avatar
To be on a safe side get a shifter for 99-00 civic SI.
Soon 2BE
Honda Civic (2006 - 2015)
May 18, 2012 11:09 AM
thanh4o8
Jan 5, 2009 05:08 AM
jdmhatch1
13
Apr 19, 2008 10:05 AM
THEDirtyDseriesWOOT
Apr 26, 2007 08:56 PM
ichibano
Apr 5, 2003 04:31 PM
