Blowing blue smoke.
Sup guys,
Currently, I am just looking on a second opinion on this.
My car is a 99 Civic Si with a b16a in it. The mods I currently have are -I/H/E. Also, my car has A CEL for the 02 sensor, and is blowing blue smoke, only in high RPM's. (5 1/2k +)
Now, I was thinking this could be related to the after market exhaust I have in the car, and/or to the fact that the O2 sensor in it is bad, and could be putting more fuel into the car. Anyone else have any suggestions to what may also cause this?
yea its either the piston rings or possibly valve stem seals. run a compression test and a cylinder leakdown test on each cylinder to locate the problem cylinder or cylinders. if you discover a cylinder that is low while doing the compression test, drop some oil down through the spark plug hole and retest. if the numbers bump up significantly then most likely its the rings that are bad. if they remain mostly unchanged then look elsewhere for the leakage. such as timing and/or valve adjustment.
From: Howcome we park on driveways, and drive on parkways?
