Megan Test Pipe
i got a megan racing test pipe recently. i installed it with the stock header and gasket. after i finished there was an air leak at the header. i was wondering if i should buy a larger than stock gasket or should i just go ahead and buy the header to go along with the pipe.
i was gonna pick one of theese up aswell. and wouldnt u want to use a new gasket anyways? get one and cut it out yourself.. how the cel doing? did u buy a o2 simli
much fail here
.......look at you stock cat upper bracket and the upper bracket of your test pipe, the bracket on the test pipe is much thinker. As a result, you have to cut down the springs on the flex joint so it remains a flex joint. If you look right now, your springs are smashed flat and the joint has no way to "float" as the motor rocks under load.
much fail here
<---Closet spelling/grammar ****.
Copper spray
the spray will not do crap, its a flex joint, the cat/test pipe is ment to slide on the cone gasket as the motor rocks under load. Get some steel motor mounts and then you do not need a flex joint anymore......of course your car will vibrate like a huge ***** after that........
-Whitey-
Jan 27, 2003 11:58 AM
