How to take off antenna???
Old Feb 16, 2009 | 06:00 PM
bsampson's Avatar
Default How to take off antenna???
ok i got all my molding and the main screw that is on antenna and all the power cords and everything tooken off but i am stuck at this part...how in the hell does this come off? and my ride is a DC2
Old Feb 16, 2009 | 06:03 PM
1Point8DC2's Avatar
Default Re: How to take off antenna???
they make a tool for that but i use the end of needle nose pliers in the opposing indents and unscrew it.
Old Feb 16, 2009 | 08:31 PM
bonstokLS's Avatar
Like it was mentioned, you can use needle nose pliers or even snap ring pliers. There are grooves on the silver cap and unscrew. It can take quite a few turns but it will pop off allowing you to slide it down and remove it from inside. Hope you have one to drop right in
Old Feb 16, 2009 | 10:15 PM
dapek's Avatar
^^ x2, I just use a flathead and push into the grooves to unscrew the top portion (silver part) slides right up and you are left with the antenna that is pulled out from inside
Old Feb 16, 2009 | 11:47 PM
DA9_DAD's Avatar
I carefully used a standard screw driver and hammer. Just lightly tap the back end of the screwdriver with the hammer, while holding the tip to one of the notches on the chromed cap. Be sure to apply a couple layers of blue tape around the area, that way if you slip the tip you won't scratch the surface. And judging by the way it looks around the base of the antenna you have rusting issues underneath your paint, I spot some bubbling.
Old Feb 18, 2009 | 08:12 PM
pantherninja's Avatar
I highly recommend getting an antenna wrench or antenna wrench tool if it is really stuck. They are not that expensive and you wont damage your antenna nut. I purchased one similar too the one on the link from Northern Tool. I had to bend the end so that I wouldn't scratch my paint. The tool that looks like a nut with teeth for the notches (antenna socket) is better though.
antenna wrend
http://toolsandmore.us/index.asp?Pag...ROD&ProdID=373
antenna sockets
http://www.matcotools.com/Catalog/to...ype=T&cat=2260
Cm91h22a
May 23, 2015 08:33 PM
GSTegTravis
Nov 13, 2007 01:36 PM
MK Ultra
Dec 6, 2006 08:17 AM
toguemaster
Suspension & Brakes
May 27, 2006 01:25 PM
Wet Nudl
Apr 30, 2002 07:17 PM
