Gt42r max hp possible ???
http://www.turbobygarrett.com/turbob...ers.html#Large
There's alot of GT42Rs. Find the one you purchased, and research it.
I DID MY RESEARCH, I KNOW THEY ARE GOOD FOR 850.
IM JUST ASKING CAUSE ALL A HEAR NOW IS BW S372 THIS AND THAT, I JUST TRYING TO GET SOME POSITIVE FEEDBACK ON THIS TURBO ANY RECOMENDATIONS ETC.
HERE ARE THE SPECS:
Inducer = 70.3mm
Exducer = 94mm
Trim = 56
AR = 0.60
Wheel dia = 82mm
Trim = 84
AR = 1.01
THE SET UP IS BASIC DARTON SLEEVES GSR BLOCK, 84.5mm BORE, STOCK STROKE, MANLEY RODS, CP PISTONS 9.1 COMPRESSION, B16 HEAD (PORTFLOW) STOCK SIZE VALVES, SKUNK2 PRO 2 CAMS, VICTORX INTAKE MANIFOLD, 1600cc ETC.
WHAT U GUYS THINK??
HERE ARE THE SPECS:
Inducer = 70.3mm
Exducer = 94mm
Trim = 56
AR = 0.60
Wheel dia = 82mm
Trim = 84
AR = 1.01
WHAT U GUYS THINK??
The 70mm can make power and run some numbers as proven over and over. If you really want to upgrade to a really nice 72mm compressor wheel/housing/backplate setup pm me and I will discuss the details with you.
HERE ARE THE SPECS:
Inducer = 70.3mm
Exducer = 94mm
Trim = 56
AR = 0.60
Wheel dia = 82mm
Trim = 84
AR = 1.01
WHAT U GUYS THINK??
HERE ARE THE SPECS:
Inducer = 70.3mm
Exducer = 94mm
Trim = 56
AR = 0.60
Wheel dia = 82mm
Trim = 84
AR = 1.01
WHAT U GUYS THINK??
