would this s/charger work for me?
I have a 93 eg with a jdm b16, would the jrsc work for me If I get a obd2 to obd1 conversion harness. Is there anything more i might need other than a retune, injectors and a new fuel pump?
this whole conversion harness deal is confusing me.... the more i look into it, it seems the obd2 to obd1 jumper is for when you run a older engine in a newer car, am I incorrect?.... i can't find a obd1 to obd2 jumper.... do they make them?
you dont need a jumper harness your car is obd1,the hondata s200 computer is obd1 ,bolt the supercharger on ,plug in the ecu ,buy some 440's like the ad says and install them and start the car lol thats the cut and dry version ofcoarse
Also check their tech articles. It will explain EVERYTHING about chipped ECU's and conversion harnesses.
John Vega is a cool guy. You can also email them with specific questions.
yea i just seen the pic that says p28-obd2b iam not sure what the deal is there , because i know a P28 is a obd1 ecu
"These are available in a standard OBD1 style plug, or you can purchase them with a built in OBD2 adapter harness for no additional cost"
thats from hondatas website , so its a P28 with a built in adapter so it plugs into the OEM obd2b harness
i see, I think i get it now, so basiclly if I run a obd2 to obd1 conversion harness on it, it should work.... kinda wierd way of doin it... the ecu is obd1 adapted to obd2, then if I use this
http://cgi.ebay.com/ebaymotors/OBD2-...Q5fAccessories
should work out..... seems messy... i dunno
you are correct hondata sells obd1 ecu's with obd2 pinsets and sockets, negating the need for a jumper harness.
i see, I think i get it now, so basically if I run a obd2 to obd1 conversion harness on it, it should work.... kinda weird way of doin it... the ecu is obd1 adapted to obd2, then if I use this
NOman0608
Jul 26, 2007 10:28 AM
