cabin harness HeLp! (pics inside)
Old Feb 15, 2009 | 04:48 PM
b_hoov's Avatar
Icon3 cabin harness HeLp! (pics inside)
my dash harness was junk, found a donor car and installed both motor/dash harness from donor car, tested my ecu ina friends car, runs fine so thats ruled out, i have 5 plugs that do not have mates, the problem i have is the donor car is same year/model but was auto not 5 spd...im thinking there is a switch/plug that needs to be jumped off so that the care thinks it's in neutral. here are the details
car- 91 dx hatch, 5 spd, mpfi conv, obd1 conv, p28 5spd ecu
donor car- 91 crx dx, auto
below are pics of the plugs that do not have homes ANY help is greatly appreciated!!!
1st pic, red plug near main relay/fuse box
2nd pic, clear plug single wire near firewall/main relay
3rd pic, green plug behind inst cluster
4th pic, near ecu mounting point, 2 plugs
5th pic, near steering column/firewall,
none of these plugs have homes, can't find anywhere would they could plug in, will this dash/cabin harness even work in this car???
help
help
help
Old Feb 15, 2009 | 05:11 PM
b_hoov's Avatar
Default Re: cabin harness HeLp! (pics inside)
c'mon peeps...help a brotha out, thats what honda-tech is 4, to help noobs with stupid q's...not my first honda but damn im having some issues!
Old Feb 15, 2009 | 05:58 PM
01-0041's Avatar
Red and green plugs are for an automatic.
You need to give more information on the others i.e. colors / pin location.
Old Feb 15, 2009 | 06:02 PM
b_hoov's Avatar
do i need to jump out any of the pins on the grn/red plugs?
all other plugs are clear
2nd pic, clear plug single wire near firewall/main relay under dash
4th pic, near ecu mounting point, 2 plugs both clear
5th pic, near steering column/firewall, clear 4 pin plug
Old Feb 15, 2009 | 08:38 PM
88efZ6's Avatar
4th pic kinda looks like heater plugs
Dr_potatohead
Dec 29, 2014 03:48 PM
SOHC Warrior
11
Jul 27, 2012 10:22 AM
powerpro_69
Mar 15, 2009 10:00 PM
Sloshy
30
Feb 7, 2006 04:58 PM
aeon
Mar 28, 2005 09:50 AM
