best and smallest frame external wastegate?
GDD's Dr. Phil?
Hey guys, two part question here, and yes I tried to search, but it sucks. I am going to an external wastegate setup, and obviously want the best. https://www.suprasport.com/Synapse-S...p_283-902.html At the same time, there will be a space issue so small is good as well. Here is what I have been looking at , is there anything better? Smaller? Thanks!
GDD's Dr. Phil?
GDD's Dr. Phil?
GDD's Dr. Phil?
GDD's Dr. Phil?
its really hard to say if a single mvs 38 is gonna hold 500whp, with a good manifold design i guess it could, with a poor manifold design HELL NO!
Here are some good pics of the mvs
https://honda-tech.com/forums/forced-induction-16/tial-38mm-vband-wg-mvs-thoughts-2481944/
I don't like the china Synapse units, will stick to TiAL.
A small wastegate will not keep you from a peak power goal, only from low power control. Wastegate size only matters when you want to run low boost on a large turbo, and then you require a large wastegate.
GDD's Dr. Phil?
https://honda-tech.com/forums/showthread.php?t=2481944
GDD's Dr. Phil?
LordVtec
Dec 24, 2002 11:42 AM
