o2 placement question on the downpipe
Old Feb 14, 2009 | 07:16 PM
turboef90's Avatar
Default o2 placement question on the downpipe
was wondering if it would make a diff if i put behind the motor instead of the front??? im runing a aem wideband as well that will be back there to
Old Feb 15, 2009 | 01:09 AM
grndcont's Avatar
Default Re: o2 placement question on the downpipe
why would you not listen to the aem instructions on their website?
http://www.aempower.com/images/produ...%2030-4100.pdf
Old Feb 15, 2009 | 03:23 AM
turboef90's Avatar
im also talking about my stock o2
Old Feb 15, 2009 | 01:40 PM
dpetro1's Avatar
Stock location should be fine. I would put the wideband first then stock o2. This is why I like plx. 2 outputs so you can delete the factory o2 and still run closed loop.
Old Feb 15, 2009 | 04:02 PM
turboef90's Avatar
i am runing both stock and my aem. just wanting to know if its ok to have them behind the motor instead of the stock one up front.
Old Feb 15, 2009 | 07:20 PM
dpetro1's Avatar
opps, im too use to the b-series having it past the oil pan from the factory. but yes you are fine. i think 24" from the turbine is the suggested distance anyways.
Tims Toy 500
18
Oct 6, 2013 02:04 PM
everythingwentblack
Nov 4, 2009 08:15 AM
iiilgsrlll
Sep 22, 2004 03:15 PM
SpeedMonkeyRacing
May 12, 2003 12:41 PM
tegtyper
Sep 3, 2002 04:33 PM
