b16a2 compression
Old Feb 14, 2009 | 07:13 PM
honda305's Avatar
Default b16a2 compression
i checked my compression today and im getting 150 across. the car when i step on it smokes really badd. is it the rings or the valve seals?
Old Feb 14, 2009 | 07:16 PM
93egSLEEPER's Avatar
Default Re: b16a2 compression
rings. have you tried to set re-seat them?
Old Feb 14, 2009 | 07:19 PM
honda305's Avatar
nah i havent
Old Feb 14, 2009 | 07:21 PM
put a DROP of ATF on top of each piston then start it and do the seating process.
Old Feb 14, 2009 | 08:43 PM
honda305's Avatar
i think its best to get new rings
Old Feb 14, 2009 | 09:08 PM
iamthefollower's Avatar
what color is the smoke?? u could possibly have blown a head gasket... but if it is the rings which it could most likely be, then driving it on bad rings you might have to have the cylinder walls honed out....
Old Feb 14, 2009 | 10:03 PM
racemycivic's Avatar
150 is real low for a b16. Do some new rings and headgasket
Old Feb 14, 2009 | 10:36 PM
D16SiHatch's Avatar
i've never heard of this before. care to elaborate?
to the OP: have you done a cylinder leakdown test? i would do a compression test again also. drop a little oil down into the cylinders and retest. if the numbers rise drastically then you can pretty safely say its the rings. if not, then for some reason your valves aren't sealing properly, and you may have valve seals leaking which would cause you to burn oil.
Old Feb 15, 2009 | 05:23 PM
honda305's Avatar
will try that
Old Feb 15, 2009 | 05:28 PM
[QUOTE=D16SiHatch;37415285]i've never heard of this before. care to elaborate?
]\QUOTE]
I had a problem where i seated my rings and my car was running good but then i let it sit a few days in extremely cold temps and for some reason i had a ring freeze up that wasnt sealing anymore. I talked to a local tuner shop and they told me to put half a capfull of atf down each cylinder, let it sit a minute or two, fire it up and drive it continuing with the break in process of new rings. all i did was start it and they instantly sealed. i had to run it hard to get the oil out and bring the compression back up but it worked nicely.
Old Feb 15, 2009 | 06:34 PM
honda305's Avatar
in before i put type r or nippon ctr pistons
slacks
Feb 21, 2008 10:57 AM
silverboost
Nov 8, 2005 01:01 PM
skunk2eg
Aug 17, 2004 12:10 PM
98civicEX
Apr 8, 2003 10:55 AM
1fastdc2
Jan 5, 2003 07:47 AM
