b18c1 build
Old Feb 14, 2009 | 07:12 PM
swepper's Avatar
Default b18c1 build
i have a question .. is it worth it to by a b18c1..and tear it down..rebuild wit forged pistons etc... i want a motor that can handle like 15- 20 lbs of boost....any recommendations on wat all internals should be replace wit wat to make it stronger.. thanx
Old Feb 14, 2009 | 07:15 PM
93egSLEEPER's Avatar
Default Re: b18c1 build
if you are going to run more then 12psi of boost i highly reccomend going with aftermarket forged internals. Eagle H beam rods and SRP 9:1 pistons would be my choice put together will all arp fasteners. While you have it apart you might as well do all the bearings and the oil pump... and check all your main seals etc.
blackccoupe
Sep 28, 2009 09:57 AM
mjfx
Jul 10, 2007 10:00 PM
aaron_morris
14
Apr 19, 2007 10:50 AM
phiberoptik
Dec 3, 2005 09:55 PM
Arch-Angel
Sep 10, 2003 10:35 AM
