...what are some good fuel injectors...
Old Feb 14, 2009 | 12:38 PM
804tuned's Avatar
Icon2 ...what are some good fuel injectors...
i have a 97 ls with a b tranny,and i'm going to do my whole fule system..injectors,fuel rail,fuel regulator,fuel pump,.i was wondering what would be a good choice for the injectors???
Old Feb 14, 2009 | 03:20 PM
mtber's Avatar
Default Re: ...what are some good fuel injectors...
What motor setup do you have?
Old Feb 14, 2009 | 06:59 PM
h224thgensedan's Avatar
Personally I am using RC saturated injectors. But like mtber said it is depending on your setup (bolt ons, headwork, fi setup,...)
Old Feb 15, 2009 | 06:50 PM
drewbie57's Avatar
If you're just doing a NA build then stock injectors will be fine.
If you going boost, then if you want to buy new ones look at Precision or RC. Or if you're cheap just get DSM 450cc blue or black tops.
The only bad injector is an undersized and under-maintained one.
Old Feb 16, 2009 | 01:40 PM
red02s2k's Avatar
RC Precision Bosch. Bosch has a new setup just ask your local tuner what he likes.
Old Feb 16, 2009 | 02:59 PM
xander1100's Avatar
one of the websites, RC i think, has a calculater that determines whast the minimum size you need.
Old Feb 22, 2009 | 06:52 PM
Tony the Tiger's Avatar
Tony1's new ID Bosch injectors are probably the best for its size
Old Feb 22, 2009 | 10:57 PM
KENetics1's Avatar
what are your mods or plans for your build OP?
Old Feb 26, 2009 | 07:49 AM
tony1's Avatar
www.InjectorDynamics.com
Hands down the best injector you can buy right now.
01_ITR
Apr 8, 2009 03:29 AM
Justin Olson
Mar 22, 2006 07:52 PM
hovic
Jun 11, 2004 07:20 AM
mrDFWmechanic
Oct 18, 2003 02:54 PM
austrian type-R
Apr 23, 2002 11:40 AM
