p & h injectors bigger than 600 why so expensive?
What brand has cheap injectors, about 650cc or so. RC is realy expensive on those sizes. What is about Venom, any good?
Re: p & h injectors bigger than 600 why so expensive? (BoostinDC2)
How many *noozels* do one Blitz injector have? My 440cc have 3 and 310cc have only one like stock.
Re: p & h injectors bigger than 600 why so expensive? (austrian type-R)
which peak and hold do yo uneed. I got the bosch injectors fairly well prices. and same with the venom ones.
Re: p & h injectors bigger than 600 why so expensive? (b18bturbo)
any difference in quality or how they operate/fit/look? Or are they all pretty much the same? referring to RC, Blitz, Bosch, and Venom injectors.
Re: (Anubyss)
What injector is the correct size to boost 20psi on built B18C with 50psi fuel press?
550, 600, 720?!?!??!
Bosch is good, do you think I can get those in Europe?
Re: p & h injectors bigger than 600 why so expensive? (Stock@$$GSR)
venom is my last hcoice in an injector if i had a choice. first woule be the bosch,rc which are = in quality second is all the other brands out there.
Re: (austrian type-R)
20 psi wow. How much power are you putting down? There is a chart for what each injector size can support at certain pressure. I know the below chart is for a b16 but looking at it, you should probably go with 720cc injectors if not more. You are using a standalone though right?
http://hondata.com/techfuelpump.html
Re: (b18bturbo)
With taht setup 720cc is the way to go. you wil lrun around 78-84% duty cylce with room to spare.
Re: (b18bturbo)
How much 4 pieces 720cc Bosch or RC peak and hold (satudated not available in that zize, right?). I would take that one, whos are cheaper.
I have a Haltech so I don´t care if p&h or sat..
Re: (b18bturbo)
Yes I think too, but I bet it´ll take a few days until the Bosch service shop in the nearest towm know what I mean. There is no big Honda aftermarket in Europe. Are those Honda injector especialy numberd or do they have a special code for the Bosch guys, so that they can understand what I need.
I run currently Lambda 0.98 at WOT which is equal to 14.5:1 . My tuner tunes all cars with turbo or n/a which have a well designed combustion camber this way for years now. But then, he has no experience with a turboed Honda. I´m now very angry to drive my car hard. I called him today and told him that the people in USA run a Lamda value of 0.90 (about 13:1), but he told me again and again it is safe for 1 Bar boost with our setted Lamda value. Oh my god, the last thing what I need is an engine which goes kabooom again!
We use 99 Octane fuel.
edit: I´ll hook up a Greddy EGT gauge in tghe next few days. On WOT runs how high should the temp be? in Celsius please
[Modified by austrian type-R, 9:27 PM 4/23/2002]
720cc Denso's at http://www.roadraceengineering.com, 420.00. I use them, work perfectly. Fitment wasnt great, but all of the large size injectors are usually slightly mis-fit for honda's.
