b20 in an ek help
Old Feb 14, 2009 | 03:49 AM
civic-one's Avatar
Default b20 in an ek help
my motor came in from hmotorsonline yesterday and i have a couple of questions. the list that came in is b20b motor complete with intake manifold and al, ls integra trans, hasport shift linkage, civic si complete mounts, and integra axles. no my question will be im not pretty sure if the trans came with the mounting bolts so would the d series trans mounting bolts fit also will i need change anything on the harness part please help me out thanks.
Old Feb 14, 2009 | 03:52 AM
xxstuntin4life's Avatar
Default Re: b20 in an ek help
ur harness will bolt up fine.. also as far as the bolts go the d and b series are the same..
btw- how much did u pay for the swap?
Old Feb 14, 2009 | 05:10 AM
gourley's Avatar
You will need to swap the intake manifold from a LS becuase the b20 intake manifold is too tall. You should also need a B-series starter. Good luck. Sounds like you got most of the parts.
ej2ndc5
Oct 15, 2010 02:53 PM
9.3.S.I.L.U.D.E.
Aug 19, 2009 10:39 AM
Capsule Kid
Mar 21, 2007 10:20 PM
hondajav06
Dec 6, 2006 11:17 AM
zerovandez
Jul 7, 2005 07:51 PM
