Anyone use the Apexi AFC NEO?
Is anyone using the apexi afc neo if so i need some help.
Can anyone share their settings with me, I'm having trouble I got the base settings for start up set but want
to start from someones maps so I can see how it works and tune and adjust to better suite my vehicle.
I am running basically stock with AEM intake, Skunk2 header, and AEM adjustable cam gears. I am mainly looking for the vtec maps but will take the rest with them.
Thanks,
Josh
Thanks,
Josh
Come on anyone? some one has to of used this product. If nothing anyone have an idea were i may find some info on how to set proper vtec and fuel points with this controller?
i have it...ive messed with it a lil but for the most part its best to have it dyno tuned... everyones car is diff and the settings cant really be used for your setup so dyno is the best result. as far as vtec the high should be around 4800 to start and low 4600
Thank you for the info I appreciate it. So dyno is the best way, I will look into finding a place around I still would appreciate any help on it that can be given.
yeah dyno is the only way to go. Don't even buy it unless your getting tuned or can tune. Other wise your just guessing at whats gonna be good for your car. Butt dyno's are inaffective as butts have no brains.
