apexi v-tec controller help
Old Jan 3, 2002 | 09:42 AM
borders79's Avatar
Default apexi v-tec controller help
Hey guys, I'm new to this forum, and drive a 99 Civic Si with cai/h/e.
A friend of mine with a similar car has an Apexi V-AFC and I was thinking of getting one myself. But we live in South Carolina, so there are no places around where we can find the most effective way to set the fuel-to-air ratio. Even the local civic tuner shops are clueless.
If you guys can give me any suggestions on how to set the controller i would appreciate it. Settings that have worked well with you would also be helpful.
Old Jan 3, 2002 | 10:07 AM
civicsidude's Avatar
New User
Default Re: apexi v-tec controller help (borders79)
you would need to dyno the car,, each car is completely different and could cause dangerous problems if you used someones settings and they are to lean or rich for your motor
Old Jan 3, 2002 | 10:31 AM
Trey's Avatar
25 Year Member
Default Re: apexi v-tec controller help (civicsidude)
Yes the dyno is the place to config the settings. You can get an A/F ratio meter to get close by the dyno will dial it in correctly.
Old Jan 3, 2002 | 01:36 PM
rflores2323's Avatar
New User
Default Re: apexi v-tec controller help (Trey)
be careful if you are trying to set the settings without a dyno! I would recommend taking a short road trip to a shop that can tune it correctly.. also the v-afc does not really give you any HP without major internal mods.. it will however give you the opportunity to tune your power line all the way thru out and to change your vtec engagement point.. thats about it!
Old Jan 3, 2002 | 02:20 PM
TODAwhore's Avatar
Default Re: apexi v-tec controller help (rflores2323)
give us a call i see you live in SC, we are in charleston and can help you tune the vafc with the dyno down here.. And welcome to H-T
[Modified by SpoonDeg, 6:23 PM 1/3/2002]
RA062424
Sep 3, 2004 06:48 PM
DangBruhY
Sep 22, 2003 11:46 AM
TypeR Freak
Sep 3, 2002 07:18 PM
tooqwik1
Aug 22, 2002 01:29 AM
Andrea_Aunie
Aug 8, 2002 04:43 PM
