00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!!
Old Aug 9, 2002 | 06:48 AM
who00knows's Avatar
Default 00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!!
Im putting a 2000 civic si motor in a 96 civic ex. What do i need to do as far as getting the ECU into it? 96-98 OBD2 is different than 99-00 OBD2. The plug configuration is different. This is a very common swap i know so any help would be greatly appreciated. thank you.
Old Aug 9, 2002 | 08:03 AM
Jackson's Avatar
Default Re: 00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!! (who00knows)
You will need to get an adapter made to use the 99-00 plugs or buy a 96-97 del sol vtec ecu, 97-98 itr ecu, or get an obd1 p30 ecu or p28. You have lots of options. I would prefer getting the obd1 ecu over the crap pt2 ecu.
Old Aug 9, 2002 | 09:24 AM
88crxoncrack's Avatar
Default Re: 00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!! (Jackson)
go for a chipped P28 with the harness converting obd2 to obd1.
someone on this board sells them for about 160-170 (it's in his sig)
Old Aug 9, 2002 | 10:48 AM
IlikeTODA's Avatar
Default Re: 00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!! (88crxoncrack)
Good thing you started with an EX. Its sometimes hard to find 96-98 VTEC harnesses. You could have just ran the VTEC wires, but somepeople don't like to do that. Just do like they said and get the DelSol ECU, 97-98 ITR, or convert to OBD1.
Thanks, J
esahic
Engine Management and Tuning
10
Jan 25, 2011 12:09 PM
hondakid09
Jan 19, 2010 02:50 PM
MiMiK
23
Sep 27, 2005 08:29 AM
KseriesSLUG
May 24, 2005 10:50 AM
Nusport_racing
Jan 27, 2004 08:31 PM
