Painting a engine bay
Old Feb 13, 2009 | 12:26 PM
Snailor Built's Avatar
Default Painting a engine bay
So this is my first time painting. Ive got a compressor, the gun and all the paint from napa. The car was black and has been primed with the green aerosol filler primer from napa also. Now were going to spray it ssbp, ive got the instructions for mixing the hardener and the reducer for the base and clear. Now what is the order or process i should do to spray it now. Heres a few more specific questions.
What should i wipe/spray the bay down with before i spray the base?
How long should i let the base sit before the clear?
Old Feb 13, 2009 | 01:25 PM
blue2000em1's Avatar
Default Re: Painting a engine bay
Wax and grease remover/Pre-paint cleaner.Check the back of the can and see what is the "window time" you have before you have to put the clear.
Old Feb 13, 2009 | 04:24 PM
precisionsc54's Avatar
normally you just wait till the base is done flashing. Times vary on temp and humidity as well as product being used. But typically 15-30 minutes. Your going to want to lay down 2 coats of base then let is flash. Denib the whole car then spray one more coat of base. Wait till its flashed then 2-3 coats of clear. If you need anymore help hit me up
Old Feb 14, 2009 | 01:59 AM
mfef4dr's Avatar
^x2
good luck with spraying the bay. Its a pita
Old Feb 14, 2009 | 09:20 PM
naterpatater77's Avatar
ya it is lots of funky angles like between the shock tower and firewall kinda have to spray and pray you got coverage. biggest thing is dont rush it
Old Feb 15, 2009 | 06:30 AM
IMPATIENT's Avatar
FIRST THING YOU NEED TO DO , is get that aerosol primer off ! the correct cleaners that youll need before you lay any of the new stuff will react with the aerosol crap and just lift and bubble all over the place. if you lay basecoat on it youll just see lots of bubbling. aerosol paints do not work with real automotive refinishing products. they will react and cause you lots of headaches. get rid of the aerosol junk before you do anything.
Old Feb 18, 2009 | 01:20 PM
93monsterbubble's Avatar
to get in the corners that are too dificult:
1)there should be a fan adjustment on the top left of the gun, turn it so the fan is smaller or on pinpoint
2)when you make the fan smaller your air pressure goes up, so readjust it to normal
3) hold the gun far back and go to town, check coverage with a flashlight
makes it alot easier the get in tight areas
Old Feb 18, 2009 | 08:27 PM
mfef4dr's Avatar
could also rotate the cap to spray up and down for the back of the shock towers
Old Feb 19, 2009 | 06:21 AM
very true
Old Feb 19, 2009 | 05:49 PM
fullyboostin's Avatar
I have painted quite a few engine bays for my friends shop. One thing I found makes a huge difference and can actually save a messed up paint job due to heat and everything is priming it before you paint it. Alot if people think you can lay down base on the base thats already their. I have done it and it works but have also seen it fail. Also it looks alot better when primed. Another thing you should consider which is something I have done is filling in all the non needed mounting holes and little things in the bay it looks so much better. Also I would pressure wash the bay then wipe it with a good degreaser.
woodenchef
Paint and Body
14
May 12, 2013 03:31 PM
Pabs626
Paint and Body
Jun 11, 2008 07:16 AM
alltech_hybrid
Paint and Body
14
Jun 11, 2007 05:25 AM
DAGSR17
Paint and Body
May 17, 2007 04:57 AM
jaydem_ekizzle
Sep 13, 2006 11:38 AM
