98 gsr with 95 gsr motor
Old Feb 13, 2009 | 10:35 AM
ZCSp0ngeR's Avatar
Default 98 gsr with 95 gsr motor
my buddy is blew his motor so he got a new gsr but its a 95. we put the motor in and it starts fine but *** soon as you give it gas it kills, the only other different thing i know of is the blox manifold on it other than that every thing is the same. any one have any ideas?
Old Feb 13, 2009 | 12:38 PM
j_bizach's Avatar
Default Re: 98 gsr with 95 gsr motor
fuel pump or tps
Old Feb 13, 2009 | 03:23 PM
ZCSp0ngeR's Avatar
both parts worked before the swap and and we have tried 2 diff TB with the TPS on them
Old Feb 13, 2009 | 03:26 PM
JRSC01GS-R's Avatar
did u get teh plugs for tps and map sensor switched
Old Feb 13, 2009 | 04:06 PM
ZCSp0ngeR's Avatar
i dont think so one is shorter than the other
Old Feb 13, 2009 | 05:59 PM
CA6VTEC's Avatar
What engine codes are you getting? You have atleast CKF code.
Old Feb 13, 2009 | 06:10 PM
ZCSp0ngeR's Avatar
i was getting a p1337 but than when i ran my obd1 i didnt get any codes
Old Feb 15, 2009 | 07:19 AM
ZCSp0ngeR's Avatar
help help help, no one has had this problem before?
Old Feb 15, 2009 | 08:05 AM
Honda1972's Avatar
Hmm, try to start the car and leaving it running and then pull a code. Check your pins on the harness and ecu also. Just trying to help.
Old Feb 15, 2009 | 09:15 AM
5GVTEC's Avatar
did he convert from obd2 to obd1?
Old Feb 15, 2009 | 09:22 AM
StokelesS_g2's Avatar
Yeah, TPS and Map sensors were switched.
GL with yours though.
allmotorgsr98
May 3, 2011 11:32 PM
aznwash3wboi
Sep 25, 2009 11:40 AM
4drteg54321
Dec 25, 2008 09:47 PM
SiHatchTurbo
May 30, 2006 05:29 PM
jennifermike
Jan 30, 2004 09:32 PM
