honda civic ex 1998 swap not running right
I just finish swapping my obd1 gsr motor in my honda civic. The car will barley want to start and idle rough. I got the jumper harness and put the obd1 p72 ecu. I also cant gas it, if i try it just act like it gonna die. Like it way out of time. I got the car to run right twice. IDK what esle to do. Any advice would help. This motor came from my running 4drteg. Is it my TPS or Map sensor? and when i un-plug my map sensor isnt it suppost to die??
Re: honda civic ex 1998 swap not running right
Yeah i have code but i cant check it because the car is obd2 but my ecu is Obd2. I've also tryed changing the map and tps around it did nothing it idles ruff AND dies if i gas it mainly it misses like the dizz is messed up or bad i have also tryed my friend p13 and the car didnt even start.
u should still be able to chech ur CEL...even if its obd2...and just a thought....u have ur spark plug wires in the right cylinders?
1SLWEJ1
02-24-2011 01:46 PM
gotboosthatch
09-15-2009 04:43 PM
zCivic
10
03-27-2006 06:59 PM
