honda civic 95 crankshaft pulley problem.
the crankshaft pulley starts to wiggle and went to local mechanic have to change the pulley we remove the crank pulley we found out theres no more key inside and the pulley lock out by itself, ok we change to a new crankshaft pulley and put the new key and tighten it. . but still has the small wiggle in it. how long this will last? is there something wrong with the crankshaft? bent? i checked the crankshaft but theres no mesh gears in it. any help would be appreciated. thanks.
We had this problem when these cars were new. Problem is, the belts, most likely the power steering belt is too tight and wallowed out the crank! Honda came out with an updated wing bolt for the ps tensioner. you most likely need a crank.
mrowxlived
Sep 9, 2017 10:54 AM
