ABS Light
Old Feb 12, 2009 | 09:45 PM
HCKRU's Avatar
Default ABS Light
Hello,
about a week ago, my ABS light went on and stays on all the time, got new rotors and pads, did the ECU reset, still same things, any one have any suggestions?
thanks
Old Feb 12, 2009 | 10:09 PM
iH8RICERZ's Avatar
Default Re: ABS Light
Have you tried jumping the ecu and try pulling the code?
Old Feb 12, 2009 | 10:13 PM
HCKRU's Avatar
thats the next thing i'm going to do. i also had a website, which defined all the codes, but after reinstalling XP lost alot of my files and favorites, SUX
Old Feb 13, 2009 | 12:23 AM
PhantomGSR's Avatar
sounds like you have the same situation. i asked my mechanic and he said to "forget it or replace it. do you really need it?" so i just drove till the light went out.
Old Feb 13, 2009 | 06:26 AM
HCKRU's Avatar
No i don't need it, but if I'm not using it, i might as well delete it, taking up a lot of space under the hood, anyone knows how to delete the ABS module, i got a shop who can do it, but i never really seen it done before,
Old Feb 15, 2009 | 05:22 PM
!ntegr@'s Avatar
Well I had my ABS light on and took it to the shop. They had this OBD digital machine that hooked up to the car and gave a 5-4 code (for my 99 gsr) which meant it was the back right sensor.
You might want to check out your sensors cuz once one of them goes bad the entire ABS system will not work. I am guessing it's one of your sensors.
See if when you put in your key and switch the ignition up once, see if you notice the ABS light initially flash couple of times, then should go on a quick pause then flash couple more times. My 5-4 code read like that .. 5 flashes a pause then 4 flashes from the ABS light before it stays lit all the time after that.
Old Feb 17, 2009 | 12:49 AM
my_hidden_romance's Avatar
try to bleed the brakes .. mine does this now and then it will come on while driving... but only after i put my bf goodrich lines on.. its just a flux in the pressure put to them...
Old Feb 17, 2009 | 01:52 AM
delbert's Avatar
i unpluggged mines so its always on. i wanna delete my abs don't really see no use for abs? to me..
zrs6v4
Honda Civic (2006 - 2015)
Jun 2, 2010 08:36 AM
ClarkS40
Mar 21, 2009 11:59 PM
pearlteg
Jul 6, 2004 05:32 PM
f22suzuka
Apr 21, 2004 10:15 AM
accordhybrid
Jun 2, 2003 02:37 PM
