Vx wheels on a stock 94 si brake setup?
Old Feb 12, 2009 | 11:46 AM
1kleenef's Avatar
Default Vx wheels on a stock 94 si brake setup?
I was wondering if anyone has run a set of vx wheels on a stock 94 si hatch with any problems with calipers hitting rims or if there is enough room? Thanks and hope to hear a response soon
Old Feb 12, 2009 | 12:24 PM
94EG8's Avatar
Seagull Management
Default Re: Vx wheels on a stock 94 si brake setup?
If its non ABS they will. If its ABS or someone installed integra front brakes then no.
Old Feb 12, 2009 | 12:26 PM
robfrmny21's Avatar
99/00 si front brake set up will not clear thoe as well
Old Feb 12, 2009 | 12:34 PM
90_EX_Civic's Avatar
wait, thought 92-95 si were 10.3???? guess i was wrong.
Old Feb 12, 2009 | 12:39 PM
1kleenef's Avatar
it is abs but why does that change the rotor size?
Old Feb 12, 2009 | 12:51 PM
don't think it's rotor per say(even though it is too) but more on the caliper, is bigger.
Old Feb 12, 2009 | 01:12 PM
94EG8's Avatar
Seagull Management
Correct EX rotors front brakes wont clear either.
No, '92 - '95 Si use the same small front brakes as the CX/DX civics. Except the '94 Si ABS models which use EX style rotors and calipers
Honda deceided to go with larger rotors and calipers on all EX coupes, Del Sol Vtecs and on all ABS models.
Old Feb 12, 2009 | 01:23 PM
stevieteg's Avatar
^ this is correct.
They are different sizes.
non abs are smaller than the abs.
Old Feb 12, 2009 | 03:17 PM
1kleenef's Avatar
is there any way to even trim the caliper? or is it a huge difference?
Old Feb 12, 2009 | 06:22 PM
94EG8's Avatar
Seagull Management
Not for VX wheels. Even HX 14" HX wheels wont fit without grinding the caliper or using wheels spacers.
bmarker
Suspension & Brakes
Jul 18, 2018 10:49 AM
hondaz6lx
Feb 7, 2007 05:32 PM
JoJoNz
19
Apr 18, 2005 02:37 PM
Vincent.
10
Nov 22, 2004 01:54 PM
Dangydang
20
Apr 22, 2003 02:10 PM
