timing belt
Old Feb 11, 2009 | 06:00 PM
spiderrey's Avatar
Default timing belt
were resetting a vtec head onto a b20 block after rebuilding the head. how much deflection should the belt have when tensioned properly? we couldnt get it right today, and i didnt like the way the belt looked, so i sent my kid away to buy a new belt and tensioner.. we will try again tommrow. sorry but our chiltons manuel really sucks.
Old Feb 12, 2009 | 06:45 AM
spiderrey's Avatar
Default Re: timing belt
c,mon you mean to tell me nobody has this info here. im trying to get my son and my stepsons tegs back on the road by saturday.i have a book , but its a chiltons, and its almost useless.
Old Feb 12, 2009 | 07:14 AM
mouab18c1's Avatar
i have a chilton and its pretty straight forward..check this thread out on how to build a
b20/ls vtec motor....
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Feb 12, 2009 | 11:12 AM
spiderrey's Avatar
thanx, i found that thread and read it this morning. havent tried it today yet. the chilton book said nothing about tightening the tensioner to keep it loose, but i will try it. the belt always seems loose between the cam wheels when the engine stops spinning . is this normal?
question if you dont mind. the guy talks about a knock sensor, the pic shows 3 things next to the oil filter mount. is the knock sensor the top one?
Old Feb 12, 2009 | 05:19 PM
PROJECT 91's Avatar
the tension between two cams can be a little loose. not to loose tho.
Old Feb 13, 2009 | 06:49 AM
mouab18c1's Avatar
there should be no more then 1/2 inch of slack on the timing belt....and about the knock sensors...its either the top blue one or the green one..not sure on that...my gsr only has one sensor around there so its much easier to identify...
Old Feb 13, 2009 | 06:56 AM
1Point8DC2's Avatar
x2^^
Old Feb 13, 2009 | 07:25 AM
spiderrey's Avatar
Thank You for the info on the belt. my son is coming over this morning with a new belt, and we will try to get it tensioned correctly.
Old Feb 13, 2009 | 02:28 PM
spiderrey's Avatar
well, we finally got the belt tensioned correctly on the 95 b 20 v tec. thanx for all the info. tommrow my boys will come back and take that motor home, its raining to hard right now. tommrow morning they will help me put the other b 20 into the 90, hope that goes smooth. thanx again.
B16a2Wa
Sep 4, 2010 12:45 PM
SolAssassin
14
Oct 2, 2009 03:09 PM
RoB316
Jul 22, 2007 03:40 PM
jsnm
Aug 29, 2005 09:44 AM
BLUE EH3
Jun 14, 2004 04:13 PM
