Safe to run all motor stage 2 cams while boosted?
Old Feb 11, 2009 | 01:42 PM
175Shot4Door's Avatar
Default Safe to run all motor stage 2 cams while boosted?
Is it safe to run all motor ls stage 2 cams on built head but a STOCK ls block? Im only looking to put down 300. I hear it makes crazy numbers but i just want to make sure its safe for 10 psi on a t3/t4 50/63 nukin manifold 3 inch dp 3 inch exhaust rc 550s. Its my daily also
Old Feb 12, 2009 | 09:37 AM
ACTION JACTION's Avatar
Default Re: Safe to run all motor stage 2 cams while boosted?
What brand cams? What lift/duration? What is "stage 2 cams". I would of advised to just get a Vtec head but since your LS is already built then you might as well just use it. Generally, a mild all motor cam works well on boosted applications considering that backpressure is low.
jdmdingdong
May 26, 2011 05:37 PM
f1tbiker6
Jan 14, 2011 10:22 AM
integranator
Nov 3, 2007 02:31 PM
eglslsd
Jul 15, 2007 10:06 AM
