Obd ii??
Old Feb 11, 2009 | 01:02 PM
reyrey2006's Avatar
Default Obd ii??
I have no idea if my car is OBD 2a or OBD 2b!!
I have a 98 Honda Civic Ex coupe manual trans and single o2 sensor if that helps.
Does anyone have any idea?? thanx
Old Feb 11, 2009 | 01:07 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Obd ii??
You're OBD2a. 99% certain that civics are 2a until either 99 or 00, and integras are 2a until 01.
Old Feb 11, 2009 | 01:10 PM
98civdx's Avatar
Master Detailer
your supposed to have 2 02 sensors,
your obd2a
Old Feb 11, 2009 | 02:50 PM
reyrey2006's Avatar
I though so too but I wasn't sure.
Old Feb 11, 2009 | 02:51 PM
reyrey2006's Avatar
your obd2a
I only have one o2 sensor is this bad?? I bought it from a dealer in San Diego, Ca and it came with a smog certificate.
Does anyone else have any idea??
Old Feb 11, 2009 | 02:52 PM
reyrey2006's Avatar
Thanks guys but I still need to be sure before I go ahead and buy an engine harness.
Old Feb 11, 2009 | 03:00 PM
carbotron's Avatar
if you want to be 100% sure look at the ECU plugs, that tells you everything. OBD2 WILL have 2 o2 sensors. basically if there's 3 rows of pins, you have OBD2, 2 rows, OBD1
here, read up on youre ECUs:
http://wikitest.pgmfi.org/twiki/bin/...ry/WireHarness
i couldnt find those pics here on HT, search is pretty much useless for looking up OBDxx so i appologize if thats a nono.
Old Feb 11, 2009 | 03:09 PM
reyrey2006's Avatar
I have a D16Y8 so it has to be a OBD2B with the link you just provided thanks
Old Feb 11, 2009 | 04:17 PM
94EG8's Avatar
Seagull Management
Civics:
OBD2A -> '96 - '98
OBD2B -> '99 - '00
Integras:
OBD2A -> '96 - '99
OBD2B -> '00 - '01
*Notes*
-HX Civic coupes remained OBD2 for the entire production run
-Most JDM OBD2 ECUs remained OBD2A For the Entire production run. CTR ECUs being a notable exception.
Old Feb 11, 2009 | 04:44 PM
reyrey2006's Avatar
Originally Posted by 94EG8
Civics:
OBD2A -> '96 - '98
OBD2B -> '99 - '00
Integras:
OBD2A -> '96 - '99
OBD2B -> '00 - '01
*Notes*
Nice!! great info thanks
Old Feb 11, 2009 | 04:55 PM
94 _EG_Swap's Avatar
is it mandatory to have 2 o2 sensor. to which one do i install the air/fuel ratio...
Old Feb 11, 2009 | 08:01 PM
98civdx's Avatar
Master Detailer
im not possitive if its mandatory, but if your trying to pass emissions then yea, obd2 civics have 2 o2s in them from honda,
im not 100% positive on this but the top. just check with a shop.
JBirch_97Prelude
Mar 4, 2006 03:33 PM
onelowchef
Nov 10, 2003 05:14 PM
BerlinaAP2
May 28, 2003 05:35 PM
ElectricBlue13
Aug 26, 2001 07:48 AM
