Transmission Problem 5th Gear and Reverse
Old Feb 11, 2009 | 09:23 AM
pArAdOxsqUArE's Avatar
Icon6 Transmission Problem 5th Gear and Reverse
I just got a 96 gsr and the transmission is having problems going into 5th gear and reverse.
it actually won't go in at all.. is the transmisison f*ck'd? or is the shift linkage bad?
I replaced and examined the shift linkage and it seems to be fine.(ruling that out)
any ideas H-T?
Old Feb 11, 2009 | 10:34 AM
TOO MUCH TORQUE's Avatar
Default Re: Transmission Problem 5th Gear and Reverse
have you attempted to do a tranny flush? 7.50 a quart, you need 2
Old Feb 11, 2009 | 02:12 PM
thewrai6th's Avatar
And all other gears shift fine?
It does sounds like a linkage problem, as 5th and reverse are on the right of the shifter and not really related to each other inside the transmission. Reverse has it's own gear.
Try both with the engine on and off.
Old Feb 11, 2009 | 02:26 PM
Dogginator's Avatar
Daisy... Daisy...
Have you checked your engine/transmission mounts?
Old Feb 12, 2009 | 07:47 PM
thanks for the reply H-T.
i heard that the fork inside is bent.
i drained the tranny and added new fluid already, stilll no progress.
i just swapped out the tranny.
thanks to who responded.
Old Feb 12, 2009 | 07:56 PM
ALLxMOTOR EG's Avatar
Vietnamese!
bad tranny,do a rebuild homey.
Old Feb 12, 2009 | 08:16 PM
Vietnamese!
Old Feb 13, 2009 | 08:50 AM
zombiemaster's Avatar
I test drove a B18a CR-X once that had the same problem. I was told it was the syncros. Supposedly 5th and R share the same syncro or something of that nature. Some one verify? I've never been inside one to know.
Old Feb 13, 2009 | 08:53 AM
EmminoDaGreat's Avatar
5th and reverse do share a synchro. If you ever take one apart just look at the stacks, and watch when you put it in reverse.
Old Feb 13, 2009 | 09:25 AM
thewrai6th's Avatar
Reverse doesn't have a synchro, but yes, 5th and reverse do share the same shift fork.
Old Feb 17, 2009 | 08:48 PM
so all i got to do is change the shift fork?
what tranny is interchangable?
is gsr in it's own class?
sorry if i'm not clear.
Old Feb 18, 2009 | 02:57 AM
wunfstgsr's Avatar
Loved
Community Favorite
bump ive been having the same problem for so long i cant figure it out i baught a gsr tranny with mf 4.9 fd, mf first gear, 2nd-5th gsr gears, quaife lsd, i had the internals swapped in my gsr tranny case and at first the reverse was really bad and fith gear grinded bad going in so i had the tranny lsd shimmed and the 5th gear replaced witha known good one and still the tranny grinds real bad going in fith but if i double clutch it wont grind i need help too with this could it be the shift fork?
Old Feb 18, 2009 | 01:22 PM
zackt_25's Avatar
New User
try the bushings or maybe something internal try new fluid just to see if it helps but idk
Old Feb 18, 2009 | 05:14 PM
wunfstgsr's Avatar
Loved
Community Favorite
ha ha.. thanks tried it though!
Old Feb 18, 2009 | 10:44 PM
FIGARILA's Avatar
Have you taken the tranny apart?
Old Feb 18, 2009 | 11:45 PM
i will try an dissamble the tranny this wkend, if i do i probably won't be able to tell anyways.
waiting to get my acura book and also got to read a few more threads and google search's.. maybe even you tube.
thanks for all the help H-T.
Old Aug 27, 2009 | 03:51 PM
GSr_09's Avatar
New User
i also got a 96 gsr and my reverse will not go in. so you say its the shift fork
Old Aug 27, 2009 | 04:09 PM
stevenDAtegra's Avatar
Shift fork or the shift change assembly. If it can't go into a gear and is stiff, that means the shift fork is either bent or the gear shift assembly isn't pushing the fork right
98bucket
Sep 17, 2008 10:09 AM
92EG8
Apr 22, 2007 12:49 PM
teamvirus
Dec 12, 2005 09:51 PM
DC24jooo
Jul 6, 2004 08:46 PM
WNYAccordLX
May 26, 2003 11:57 AM
