H22 hatch problems
Ok I have a 1994 honda civic vx hatch with a 93 jdm h22a and my question is;
Do all H22 hatches front wheels sit off centered to the back of the wheel well and make the steering wheel shake while accelerating.
you need to check your combonation of what axle you are running and what mounts you are running and if they go together...i was having the same problem in my ek coupe with a harsh vibration when accelerating, my axles where going bad and i believe were the wrong ones for the mounts i was using do to the vibrating. so i ordered new axles for the car and mounts i had from raxles.com and havent had a problem since
ok??????????????????????????
It sounds like you need to get under your vehicle and inspect your suspension, axles, ball joints, ect. If you have excessive shaking it could be something as simple as a loose bolt...or loose motor mounts. As for the off center wheels, it sounds like the axle setup you have is incorrect. Maybe you should try to look into that...(research, call hasport, ect)
im just not understanding what an axle has to do with wheel placement when i get underneath my car all i see is an axle that is cocked on both sides i know that on ef 's there is a tie rod that would enable to adjust this sorta thing i just cant imagine why the next generation would not have any sorta adjustment
sorry for the pain in the a** questions
